Using LMS to extract VRF name as a variable from device config to deploy VRF name in additional configuration
mdwheadon
Using LMS is there a way to run a job which would extract the VRF name in part of the configuration and then use it as a variable to deploy additional configuration using the VRF name. We have a number of management VRF's and need to deploy a mass configuration change on a number of devices.
aaa group server tacacs+ blah
server x.x.x.x
server x.x.x.x
ip vrf forwarding test
mdwheadon
Sorry I should have added the value I wanted to extract was called test to use it as part of new configuration.
From the below snipit.
server x.x.x.x
server x.x.x.x
I am working for a service provider and I was given a task to configure more than 50000 devices (!). First I started with VBS and some scriptable terminal application, but it was too complicated to handle that much data. I then decided to develop my own application dedicated to device mass-configuration. As I understand your question, you may also find it useful : http://www.prettygoodterminal.com
BR
