01-26-2010 08:59 PM
hello
CWLMS 3.2 can see most of computers in UT end host.
However we have some servers that it cannot see. These one are located in ASA firewall DMZs.
Is this normal ? or is there any way to let it see these servers?.
Notes:
1- CW can ping these servers
2- These servers are connected to discovered Cisco switches
Solved! Go to Solution.
02-01-2010 07:17 AM
Your SNMPv3 configuration looks wrong. You've assigned the VLAN contexts to a group, campusgroup; however, I think you wanted to assign them to MLMg. That is, you need to use the group of which your SNMPv3 user is a member.
01-26-2010 10:52 PM
These end hosts should be visible in UT provided the switches are data collected by Campus, and show up as green on the Campus topology map. In other words, there should be nothing different between UT getting end hosts from these switches vs. any others on the network. The only problem you may see is that UT will not get their IP addresses as it sounds like the ASA is routing for these DMZs, and Campus does not support firewalls for getting the ARP table.
01-27-2010 12:20 AM
yes joe
for routers connected to this switch, i can see them green in campus topology map.
however if i search for windows PC in this switch, using user tracking or UT End Host Report i can't find any PC!!!.
so if i understand your answer, this is normal and there is no workaround ! isn't it?
01-27-2010 07:25 PM
Routers or switches? End hosts connected to routers (even those with switch modules) will not show up in UT. End hosts connected to switches should show up, but you may only be able to search for them by MAC address.
01-27-2010 09:12 PM
hi joe
no, i am not speaking about end hosts connected to routers. i am searching for our public servers connected to DMZ using VLANs in one discovered switch.
well, i tried seraching them by MAC address but i can't find any one!
01-29-2010 06:52 PM
Post a show run and show ver from one affected DMZ switch. Also post the "show int status" and "show mac-address-table" outputs from this switch. From the server, post the NMSROOT/campus/etc/cwsi/portsData.xml and vlanData.xml files.
01-30-2010 11:20 PM
attached file contains the requested infos for switch 10.151.50.1
01-30-2010 11:29 PM
Sho version
internet sw#sho version
Cisco IOS Software, C3750 Software (C3750 IPBASE M), Version 12.2(35)SE5, RELEASE SOFTWARE (fc1)
Copyright (c) 1986 2007 by Cisco Systems, Inc.
Compiled Thu 19 Jul 07 19:15 by nachen
Image text base: 0x00003000, data base: 0x01080000
ROM: Bootstrap program is C3750 boot loader
BOOTLDR: C3750 Boot Loader (C3750 HBOOT M) Version 12.2(25r)SEC, RELEASE SOFTWARE (fc4)
internet sw uptime is 2 weeks, 4 days, 19 hours, 47 minutes
System returned to ROM by power on
System restarted at 11:09:56 UTC Tue Jan 12 2010
System image file is "flash:c3750 ipbase mz.122 35.SE5/c3750 ipbase mz.122 35.SE5.bin"
cisco WS C3750 48P (PowerPC405) processor (revision M0) with 118784K/12280K bytes of memory.
Processor board ID FDO1302X0WD
Last reset from power on
3 Virtual Ethernet interfaces
48 FastEthernet interfaces
4 Gigabit Ethernet interfaces
The password recovery mechanism is enabled.
512K bytes of flash simulated non volatile configuration memory.
Base ethernet MAC Address : 00:24:97:B5:72:80
Motherboard assembly number : 73 9675 13
Power supply part number : 341 0029 05
Motherboard serial number : FDO13020M0B
Power supply serial number : LIT12490CVL
Model revision number : M0
Motherboard revision number : B0
Model number : WS C3750 48PS S
System serial number : FDO1302X0WD
SFP Module assembly part number : 73 7757 03
SFP Module revision Number : A0
SFP Module serial number : FDO13020CND
Top Assembly Part Number : 800 25858 04
Top Assembly Revision Number : C0
Version ID : V06
CLEI Code Number : COMUX10ARA
Hardware Board Revision Number : 0x01
Switch Ports Model SW Version SW Image
* 1 52 WS C3750 48P 12.2(35)SE5 C3750 IPBASE M
Configuration register is 0xF
Sho run
hostname internet sw
enable secret xxxxxxxxxxxxxxxxxxxx
username swadmin password 7 xxxxxxxxxxxxxxxxx
aaa session id common
switch 1 provision ws c3750 48p
system mtu routing 1500
vtp mode transparent
ip subnet zero
no file verify auto
spanning tree mode pvst
spanning tree extend system id
no spanning tree vlan 1
vlan internal allocation policy ascending
vlan 151 155
interface FastEthernet1/0/1
switchport access vlan 151
speed 100
duplex full
spanning tree portfast
interface FastEthernet1/0/2
speed 100
interface FastEthernet1/0/47
speed 100
duplex full
interface FastEthernet1/0/48
description PDM
speed 100
duplex full
interface GigabitEthernet1/0/1
interface GigabitEthernet1/0/2
interface GigabitEthernet1/0/3
interface GigabitEthernet1/0/4
interface Vlan1
no ip address
no ip route cache
shutdown
interface Vlan151
ip address 10.151.50.1 255.255.0.0
no ip route cache
interface Vlan154
no ip address
no ip route cache
shutdown
ip default gateway 10.w.w.w
ip classless
ip access list standard SNMP SERVERS
permit 10.x.y.z
permit 10.x.y.t
logging trap debugging
logging 10.x.y.z
access list 1 permit 10.x.y.z
snmp server engineID local 000000090200003085F0F480
snmp server group MLMg v3 auth access SNMP SERVERS
snmp server group MLMu_2oo9 v3 auth notify *tv.FFFFFFFF.FFFFFFFF.FFFFFFFF.FFFFFFFF0F
snmp server group campusgroup v3 auth context DMZ read campusview write campusview
snmp server group campusgroup v3 auth context vlan 1 read campusview write campusview
snmp server group campusgroup v3 auth context vlan 151 read campusview write campusview
snmp server group campusgroup v3 auth context vlan 152 read campusview write campusview
snmp server group campusgroup v3 auth context vlan 154 read campusview write campusview
snmp server group campusgroup v3 auth context vlan 155 read campusview write campusview
snmp server view campusview internet included
snmp server location Internet Edge
snmp server enable traps snmp authentication linkdown linkup coldstart warmstart
snmp server enable traps tty
snmp server enable traps cluster
snmp server enable traps fru ctrl
snmp server enable traps entity
snmp server enable traps cpu threshold
snmp server enable traps power ethernet group 1 9
snmp server enable traps vtp
snmp server enable traps vlancreate
snmp server enable traps vlandelete
snmp server enable traps flash insertion removal
snmp server enable traps port security
snmp server enable traps envmon fan shutdown supply temperature status
snmp server enable traps mac notification
snmp server enable traps stackwise
snmp server enable traps license
snmp server enable traps config copy
snmp server enable traps hsrp
snmp server enable traps rtr
snmp server enable traps bridge newroot topologychange
snmp server enable traps stpx inconsistency root inconsistency loop inconsistency
snmp server enable traps syslog
snmp server enable traps vlan membership
snmp server host 10.x.y.z version 3 auth MLMu_2oo9
tacacs server host 10.e.e.e. key 7 qqqqqq
tacacs server directed request
radius server source ports 1645 1646
control plane
internet sw#sho interfaces status
Port Name Status Vlan Duplex Speed Type
Fa1/0/1 notconnect 151 full 100 10/100BaseTX
Fa1/0/2 notconnect 151 full 100 10/100BaseTX
Fa1/0/3 connected 151 full 100 10/100BaseTX
Fa1/0/4 notconnect 151 full 100 10/100BaseTX
Fa1/0/5 connected 151 full 100 10/100BaseTX
Fa1/0/6 notconnect 151 full 100 10/100BaseTX
Fa1/0/7 connected 151 full 100 10/100BaseTX
Fa1/0/8 connected 151 full 100 10/100BaseTX
Fa1/0/9 connected 151 full 100 10/100BaseTX
Fa1/0/10 connected 151 full 100 10/100BaseTX
Fa1/0/11 connected 152 full 100 10/100BaseTX
Fa1/0/12 connected 152 full 100 10/100BaseTX
Fa1/0/13 notconnect 152 full 100 10/100BaseTX
Fa1/0/14 connected 152 full 100 10/100BaseTX
Fa1/0/15 connected 152 full 100 10/100BaseTX
Fa1/0/16 notconnect 153 full 100 10/100BaseTX
Fa1/0/17 connected 152 full 100 10/100BaseTX
Fa1/0/18 notconnect 153 full 100 10/100BaseTX
Fa1/0/19 notconnect 153 full 100 10/100BaseTX
Fa1/0/20 notconnect 153 full 100 10/100BaseTX
Fa1/0/21 connected 154 full 100 10/100BaseTX
Fa1/0/22 connected 154 full 100 10/100BaseTX
Fa1/0/23 notconnect 154 full 100 10/100BaseTX
Fa1/0/24 notconnect 154 full 100 10/100BaseTX
Fa1/0/25 connected 154 full 100 10/100BaseTX
Fa1/0/26 notconnect 154 full 100 10/100BaseTX
Fa1/0/27 notconnect 154 full 100 10/100BaseTX
Fa1/0/28 notconnect 154 full 100 10/100BaseTX
Fa1/0/29 notconnect 154 full 100 10/100BaseTX
Fa1/0/30 notconnect 154 full 100 10/100BaseTX
Fa1/0/31 connected 155 full 100 10/100BaseTX
Fa1/0/32 connected 155 full 100 10/100BaseTX
Fa1/0/33 connected 155 full 100 10/100BaseTX
Fa1/0/34 connected 155 full 100 10/100BaseTX
Fa1/0/35 notconnect 155 full 100 10/100BaseTX
Fa1/0/36 connected 155 full 100 10/100BaseTX
Fa1/0/37 connected 155 full 100 10/100BaseTX
Fa1/0/38 connected 155 full 100 10/100BaseTX
Fa1/0/39 connected 155 full 100 10/100BaseTX
Fa1/0/40 connected 155 full 100 10/100BaseTX
Fa1/0/41 connected 151 full 100 10/100BaseTX
Fa1/0/42 notconnect 151 full 100 10/100BaseTX
Fa1/0/43 connected 151 full 100 10/100BaseTX
Fa1/0/44 connected 155 full 100 10/100BaseTX
Fa1/0/45 notconnect 1 full 100 10/100BaseTX
Fa1/0/46 notconnect 1 full 100 10/100BaseTX
Fa1/0/47 notconnect 1 full 100 10/100BaseTX
Fa1/0/48 connected 151 full 100 10/100BaseTX
Gi1/0/1 notconnect 1 auto auto Not Present
Gi1/0/2 notconnect 1 auto auto Not Present
Gi1/0/3 notconnect 1 auto auto Not Present
Gi1/0/4 notconnect 1 auto auto Not Present
internet sw#sho mac address table
Mac Address Table
Vlan Mac Address Type Ports
All 0100.0ccc.cccc STATIC CPU
All 0100.0ccc.cccd STATIC CPU
All 0180.c200.0000 STATIC CPU
All 0180.c200.0001 STATIC CPU
All 0180.c200.0002 STATIC CPU
All 0180.c200.0003 STATIC CPU
All 0180.c200.0004 STATIC CPU
All 0180.c200.0005 STATIC CPU
All 0180.c200.0006 STATIC CPU
All 0180.c200.0007 STATIC CPU
All 0180.c200.0008 STATIC CPU
All 0180.c200.0009 STATIC CPU
All 0180.c200.000a STATIC CPU
All 0180.c200.000b STATIC CPU
All 0180.c200.000c STATIC CPU
All 0180.c200.000d STATIC CPU
All 0180.c200.000e STATIC CPU
All 0180.c200.000f STATIC CPU
All 0180.c200.0010 STATIC CPU
All ffff.ffff.ffff STATIC CPU
151 000b.cddc.47c4 DYNAMIC Fa1/0/8
151 000c.7606.d853 DYNAMIC Fa1/0/48
151 0012.79d3.67d6 DYNAMIC Fa1/0/9
151 0013.21b1.d29e DYNAMIC Fa1/0/5
151 0018.fe78.5676 DYNAMIC Fa1/0/41
151 001b.783a.d72c DYNAMIC Fa1/0/3
151 001f.29e8.1f8e DYNAMIC Fa1/0/43
151 0021.a0af.e8f8 DYNAMIC Fa1/0/7
151 0024.1413.88c4 DYNAMIC Fa1/0/10
151 03bf.0a97.0a78 STATIC Fa1/0/8 Fa1/0/41
152 0006.53f5.e020 DYNAMIC Fa1/0/17
152 0019.bbd2.a852 DYNAMIC Fa1/0/11
152 001a.4b4d.ce50 DYNAMIC Fa1/0/14
152 0021.a0af.e8fa DYNAMIC Fa1/0/15
152 0024.1413.88c6 DYNAMIC Fa1/0/12
155 0013.21b1.54ae DYNAMIC Fa1/0/44
155 0014.384b.0ef4 DYNAMIC Fa1/0/38
155 0015.6057.1599 DYNAMIC Fa1/0/32
155 0019.bbd2.8c12 DYNAMIC Fa1/0/39
155 001a.4b50.9e0e DYNAMIC Fa1/0/37
155 001e.0bd7.16c0 DYNAMIC Fa1/0/34
155 0021.a0af.e8f9 DYNAMIC Fa1/0/36
155 0024.1413.88c5 DYNAMIC Fa1/0/33
155 0025.b320.866e DYNAMIC Fa1/0/40
155 0025.b321.188e DYNAMIC Fa1/0/31
154 001b.54df.a64a DYNAMIC Fa1/0/22
154 0021.a0af.e8fb DYNAMIC Fa1/0/25
154 0024.1413.88c7 DYNAMIC Fa1/0/21
Total Mac Addresses for this criterion: 48
02-01-2010 07:17 AM
02-01-2010 10:39 PM
oh yes! i forgot to change this in these switches.
thank you joe. you should change your avatar from devil to angel :-)
01-31-2010 01:37 AM
i was not able to attach portdata and vlandata details. so i publish them here:
