Utilization of a switch backplane in LMS
scott_matthews
I am trying to see the Utilization of the entire backplane of a Cisco 6509 in LMS.  I can only find a way to see the utilization of each individual interface, and not the entire device.  I would like to see this because I want to not only see the traffic going out on the uplink, but I would also like to see the traffic passed from one interface to the other.  Is there a way for me to see the utilization of the entire device in LMS?
19 Replies 19
Try deleting this file.  And make sure the NMSROOT/hum/mibmanager/mibcompiler/mibs/CISCO-STACK-MIB.my file is exactly 489692 bytes.  Then try loading it again.
I deleted the .xml file, verified the size of the MIB file is the filesize you stated, and attempted to load the MIB again.
I am still getting the same error about unable to serialize the object into the database.
I think there might be a problem with some of your other MIBs.  Here is a zip of all of my NMSROOT/hum/mibmanager/mibcompiler/mibs directory.  Replace your mibs directory with the contents of this file, delete the CISCO-STACK-MIB.xml file again, then see if the STACK-MIB will load.
Joe,
     I wiped out my entire MIBS folder, and copied in all the MIBS contained in the zip file you attached.  After doing this, the CISCO STACK MIB loaded with no problems.
I'm guessing there was some issue with one of the MIBS I had in the folder??
Thanks for all your help.
-Scott
Yes, this is what I suspected.
