02-22-2010 06:52 AM
I am trying to see the Utilization of the entire backplane of a Cisco 6509 in LMS. I can only find a way to see the utilization of each individual interface, and not the entire device. I would like to see this because I want to not only see the traffic going out on the uplink, but I would also like to see the traffic passed from one interface to the other. Is there a way for me to see the utilization of the entire device in LMS?
02-26-2010 12:42 PM
Try deleting this file. And make sure the NMSROOT/hum/mibmanager/mibcompiler/mibs/CISCO-STACK-MIB.my file is exactly 489692 bytes. Then try loading it again.
02-26-2010 12:50 PM
I deleted the .xml file, verified the size of the MIB file is the filesize you stated, and attempted to load the MIB again.
I am still getting the same error about unable to serialize the object into the database.
02-27-2010 10:23 AM
03-01-2010 12:01 PM
Joe,
I wiped out my entire MIBS folder, and copied in all the MIBS contained in the zip file you attached. After doing this, the CISCO STACK MIB loaded with no problems.
I'm guessing there was some issue with one of the MIBS I had in the folder??
Thanks for all your help.
-Scott
03-01-2010 12:49 PM
Yes, this is what I suspected.
