UTLite
bcarroll
Level 3
Level 3
When using the UTLite for user tracking, what username will be seen if a user logs into a Windows machine, and then uses a Novell client to log into NDS?
mchin345
Level 11
Level 11
The user name functionality of UTLite depends on software on the Windows domain controller that the users authenticate to
running a script when they log on. User tracking is supported with Active Directory. If you look at the UTLiteNT.bat file, you can modify it to reflect the AD domain name that the user account belongs to as well as the address/port of the CW2K server. We are currently using this across numerous Windows based systems including WinXP running SP2. Once you have this script modified, you just need to call it from within the users logon script within AD. This will launch the utlite33.exe program and the username of the person logging in will be reported to CW2K.
