Various LMS Errors
Gerren Murphy
Visitor
A new install of LMS 4.0 is showing the following error(s) in various parts of the UI:
1. JRM server is down  or inaccessible for this user (Admin > System)
2. Error in communicating with DCR Server. (Inventory > Add/Import/Manage Devices)
3. Self Test Fail to query ani.DbVersion Error: Invalid user ID or password (DBD: login failed)
Thanks for any and all assistance.
5 Replies 5
Joe Clarke
Post the output of pdshow from this server.
That's what's tough, every time I've run that command, it says something along the lines of the daemon is busy doing other things, please try again later. I don't remember the exact verbiage, and can't get in at the moment to get it either.
When I run the self-test, it shows pass on everything but the database connection. I tried installing LMS  both in the "basic" install mode where the system generates a DB password, and in advanced mode and I specified a password. Both ways got the same result.
This is on a box where 3.2 was previously installed then uninstalled, so I'm wondering if it's a registry key somewhere that's the issue. Should have more for you on Wednesday.
Yes, the command will hang, but that's because you have a failing process that we to troubleshoot.  If you wait long enough (up to an hour).  The command will return useful data.  Wait until it does, then post the output.
Output of pdshow
    Process= UPMDbEngine
    State  = Program started - No mgt msgs received
    Pid    = 312
    RC     = 0
    Signo  = 0
    Start  = 1/17/2011 2:18:00 PM
    Stop   = Not applicable
    Core   = Not applicable
    Info   = Application started by administrator request.
    Process= UPMDbMonitor
    State  = Running normally
    Pid    = 132
    RC     = 0
    Signo  = 0
    Start  = 1/17/2011 2:18:04 PM
    Info   = DbMonitor Running Normally.
    Process= Tomcat
    Pid    = 196
    RC     = 0
    Signo  = 0
    Start  = 1/17/2011 2:18:08 PM
    Process= TomcatMonitor
    Pid    = 2896
    RC     = 0
    Signo  = 0
    Start  = 1/17/2011 2:18:12 PM
    Info   = Tomcat Server up
    Process= Apache
    Pid    = 3904
    RC     = 0
    Signo  = 0
    Start  = 1/17/2011 2:21:42 PM
    Process= RMEDbEngine
    State  = Never started
    Pid    = 0
    RC     = 0
    Signo  = 0
    Start  = N/A
    Info   = Not applicable,
    Process= Proxy
    Pid    = 5628
    RC     = 0
    Signo  = 0
    Start  = 1/17/2011 2:25:02 PM
    Info   = Server started by admin request
    Process= NameServer
    Pid    = 5636
    RC     = 0
    Signo  = 0
    Start  = 1/17/2011 2:25:03 PM
    Process= NameServiceMonitor
    Pid    = 5700
    RC     = 0
    Signo  = 0
    Start  = 1/17/2011 2:25:07 PM
    Info   = NameServer is fully up now !
    Process= EDS
    Pid    = 5740
    RC     = 0
    Signo  = 0
    Start  = 1/17/2011 2:25:11 PM
    Info   = Initialization complete
    Process= EDS-GCF
    Pid    = 6000
    RC     = 0
    Signo  = 0
    Start  = 1/17/2011 2:26:29 PM
    Info   = GCF Initialization complete at Mon Jan 17 14:27:29 EST 2011
    Process= LicenseServer
    Pid    = 6008
    RC     = 0
    Signo  = 0
    Process= INVDbEngine
    Pid    = 6016
    RC     = 0
    Signo  = 0
    Start  = 1/17/2011 2:26:31 PM
    Process= FHPurgeTask
    Pid    = 0
    RC     = 0
    Signo  = 0
    Start  = N/A
    Process= FHDbEngine
    Pid    = 2868
    RC     = 0
    Signo  = 0
    Start  = 1/17/2011 2:26:37 PM
    Process= ESS
    Pid    = 1588
    RC     = 0
    Signo  = 0
    Start  = 1/17/2011 2:26:41 PM
    Process= EssMonitor
    Pid    = 2716
    RC     = 0
    Signo  = 0
    Start  = 1/17/2011 2:26:45 PM
    Info   = ESS is fully up now !
    Process= DCRServer
    State  = Failed to run
    Pid    = 0
    RC     = -3
    Signo  = 1073741821
    Start  = N/A
    Stop   = 1/17/2011 3:30:31 PM
    Info   = Application failed or was registered incorrectly.
    Process= CMFOGSServer
    State  = Administrator has shut down this server
    Pid    = 0
    RC     = 0
    Signo  = 0
    Start  = 1/17/2011 2:31:46 PM
    Process= EssentialsDM
    Pid    = 0
    RC     = 0
    Signo  = 0
    Start  = N/A
    Process= ConfigMgmtServer
    Pid    = 0
    RC     = 0
    Signo  = 0
    Start  = N/A
    Process= ConfigUtilityService
    Pid    = 0
    RC     = 0
    Signo  = 0
    Start  = N/A
    Process= ICServer
    Pid    = 0
    RC     = 0
    Signo  = 0
    Start  = N/A
    Process= EnergyWise
    Pid    = 0
    RC     = 0
    Signo  = 0
    Start  = N/A
    Process= PMCOGSServer
    Pid    = 7444
    RC     = 0
    Signo  = 0
    Process= IPMOGSServer
    Pid    = 0
    RC     = 0
    Signo  = 0
    Process= TISServer
    Pid    = 0
    RC     = 0
    Signo  = 0
    Start  = N/A
    Process= DFMOGSServer
    Pid    = 7468
    RC     = 0
    Signo  = 0
    Process= InventoryCollector
    Pid    = 0
    RC     = 0
    Signo  = 0
    Start  = N/A
    Process= Interactor
    Pid    = 0
    RC     = 0
    Signo  = 0
    Start  = N/A
    Process= InventoryCollector1
    Pid    = 0
    RC     = 0
    Signo  = 0
    Start  = N/A
    Process= Interactor1
    Pid    = 0
    RC     = 0
    Signo  = 0
    Start  = N/A
    Process= PTMServer
    Pid    = 7652
    RC     = 0
    Signo  = 0
    Start  = 1/17/2011 2:31:50 PM
    Process= UPMProcess
    Pid    = 0
    RC     = 0
    Signo  = 0
    Start  = N/A
    Process= EventFramework
    Pid    = 7660
    RC     = 0
    Signo  = 0
    Process= jrm
    Pid    = 0
    RC     = 1
    Signo  = 0
    Start  = 1/17/2011 3:12:10 PM
    Process= CTMJrmServer
    Pid    = 0
    RC     = 0
    Signo  = 0
    Start  = N/A
    Process= ChangeAudit
    Pid    = 0
    RC     = 0
    Signo  = 0
    Start  = N/A
    Process= SyslogAnalyzer
    Pid    = 0
    RC     = 0
    Signo  = 0
    Start  = N/A
    Process= DataPurge
    Pid    = 0
    RC     = 0
    Signo  = 0
    Start  = N/A
    Process= IPMProcess
    Pid    = 0
    RC     = 0
    Signo  = 0
    Start  = N/A
    Process= TISDiscoveryJobCreate
    Pid    = 0
    RC     = 0
    Signo  = 0
    Start  = N/A
    Process= PMServer
    Pid    = 5592
    RC     = 0
    Signo  = 0
    Start  = 1/17/2011 2:40:10 PM
    Info   = PMServer is up and running
    Process= SyslogCollector
    Pid    = 5624
    RC     = 0
    Signo  = 0
    Start  = 1/17/2011 2:40:14 PM
    Info   = SyslogCollector Started at Mon Jan 17 14:40:14 EST 2011
    Process= EPMDbEngine
    Pid    = 0
    RC     = 0
    Signo  = 0
    Start  = N/A
    Process= EPMServer
    Pid    = 0
    RC     = 0
    Signo  = 0
    Start  = N/A
    Process= FHServer
    Pid    = 0
    RC     = 0
    Signo  = 0
    Start  = N/A
    Process= NOSServer
    Pid    = 0
    RC     = 0
    Signo  = 0
    Start  = N/A
    Process= diskWatcher
    Pid    = 6612
    RC     = 0
    Signo  = 0
    Start  = 1/17/2011 2:43:34 PM
    Info   = diskWatcher initialized OK.
    Process= DFMMultiProcLogger
    Pid    = 6492
    RC     = 0
    Signo  = 0
    Process= DFMLogServer
    Pid    = 7112
    RC     = 0
    Signo  = 0
    Process= DFMCTMStartup
    Pid    = 0
    RC     = 0
    Signo  = 0
    Process= DfmBroker
    Pid    = 7232
    RC     = 0
    Signo  = 0
    Process= DfmServer
    Pid    = 7272
    RC     = 0
    Signo  = 0
    Start  = 1/17/2011 2:43:38 PM
    Info   = DfmServer initialized OK.
    Process= DfmServer1
    Pid    = 7300
    RC     = 0
    Signo  = 0
    Info   = DfmServer1 initialized OK.
    Process= DCRDevicePoll
    Pid    = 0
    RC     = 0
    Signo  = 0
    Start  = N/A
    Process= CSRegistryServer
    Pid    = 7304
    RC     = 0
    Signo  = 0
    Info   = CSRegistryServer is running in other process
    Process= CSDiscovery
    Pid    = 0
    RC     = 0
    Signo  = 0
    Start  = N/A
    Process= ANIDbEngine
    Pid    = 7312
    RC     = 0
    Signo  = 0
    Start  = 1/17/2011 2:43:40 PM
    Process= ANIServer
    Pid    = 0
    RC     = 0
    Signo  = 0
    Start  = N/A
    Process= UTMajorAcquisition
    Pid    = 0
    RC     = 0
    Signo  = 0
    Start  = N/A
    Process= MACUHIC
    Pid    = 7836
    RC     = 0
    Signo  = 0
    Start  = 1/17/2011 2:43:44 PM
    Info   = Started.
    Process= UTLITE
    Pid    = 7740
    RC     = 0
    Signo  = 0
    Start  = 1/17/2011 2:43:45 PM
    Info   = Started.
    Process= UTManager
    Pid    = 0
    RC     = 0
    Signo  = 0
    Start  = N/A
    Process= WlseUHIC
    Pid    = 0
    RC     = 0
    Signo  = 0
    Start  = N/A
    Process= AdapterServer1
    Pid    = 7708
    RC     = 0
    Signo  = 0
    Pid    = 7672
    RC     = 0
    Signo  = 0
Looks like there is a problem with DCRServer.  Please post the dcr.log and DCRServer.log.  There also appears to be an issue with the RME database.  Have a look at https://supportforums.cisco.com/docs/DOC-8796 .  Try performing transaction log recovery on the RME database.  If that does not work, you will either need to reinitialize the RME database or restore LMS from a known good backup.
