ā09-21-2015 09:25 AM
Hello:
We are planning to replace old Cisco 3560 and 4505 switches. (currently I have a single voice vlan and data vlan).
Is it a good idea to create multiple vlans (ex: voice vlan, printers on another vlan, security camera on separate vlan etc)etc?
Currently I have 260 cisco phones, 320 computers and 15 network printers and 32 IP security cameras. ( all in 5 floors)
Alexander Thazhayil
ā09-21-2015 11:39 AM
Hi Alex ,
I would say yes! , It is a good idea to segregate the traffic types into VLANs , that way you will improve the QoS of the video and voice devices and add an extra layer of security to the switch.
If your network design allow it , you can create separate VLANs for every type of traffic.
You can also create one VLAN per floor to separate the broadcast domains.
Hope it helps
-Randy-
ā11-04-2015 09:44 AM
It's highly recommended to do so.
You should use a vlan for each service (phones, computers and printers with client isolation off, and cctv).
