12-29-2009 01:16 PM
I have several WAAS units all WAE-512-K9 which are listed in RME device supported by Cisco Works, all running 4.1.X and above
How ever they have an OID:xx.9.1.760 where as Cisco Works only supports OID:xx.9.1.759 & 776. So the units are "unknown" in Ciscoworks. Are the Units that different.
Is there any way to update the OID to get the units fully supported by CiscoWorks to enable monitoring.
RME is 4.2.0
12-29-2009 01:19 PM
Sorry RME is 4.3.0
12-29-2009 01:24 PM
No, this device is not yet supported, and I do not have an ETA on when support will be available. I have, however, requested support get added.
12-30-2009 01:25 AM
Thanks Jo
01-11-2010 10:49 PM
What version of code is this device running? There is a question about whether this is an FE-512-K9 running WAFS code (which is EoL). The OE-512-K9 version should be supported now in RME.
01-12-2010 03:25 AM
Hi Jo,
Here is the info of the device any further info please let me know :
UKHSL-WAAS01#sh inv
PID: WAE-512-K9 VID: 0 SN: KQZ6637
UKHSL-WAAS01#sh ver
Cisco Wide Area Application Services Software (WAAS)
Copyright (c) 1999-2009 by Cisco Systems, Inc.
Cisco Wide Area Application Services Software Release 4.1.5b (build b7 Oct 27 2009)
Version: fe512-4.1.5b.7
Compiled 19:29:00 Oct 27 2009 by cnbuild
System was restarted on Sun Dec 13 14:52:41 2009.
The system has been up for 4 weeks, 1 day, 20 hours, 29 minutes, 23 seconds.
UKHSL-WAAS01#
01-12-2010 09:20 AM
This code is certainly not EoL. I'm rechecking with development for support.
01-13-2010 04:12 AM
Hi Jo,
Just to provide you with some info here.
When we purchased our WAAS units, Cisco had just announced WAAS so we where right in the middle of WAFS and WAAS, going WAAS on the implementation and I have been maintaining it ever since.
01-14-2010 04:45 AM
Hi Jo,
Thought I would also add this snmpwalk of one of my units show the OID number, all units are the same.
SNMPv2-MIB::sysDescr.0 = STRING: Cisco Wide Area Application Services Software Hardware Version: fe512-4.1.5b.7
Cisco Wide Area Application Services Software Software Release 4.1.5b (build b7 Oct 27 2009)
SNMPv2-MIB::sysObjectID.0 = OID: SNMPv2-SMI::enterprises.9.1.760
DISMAN-EVENT-MIB::sysUpTimeInstance = Timeticks: (275685900) 31 days, 21:47:39.00
SNMPv2-MIB::sysContact.0 = STRING: xxxxxxxxxxxxxxxxxxxxxxxxxxx
SNMPv2-MIB::sysName.0 = STRING: xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
SNMPv2-MIB::sysLocation.0 = STRING: xxxxxxxxxxxxxxxxxxxxxx
SNMPv2-MIB::sysServices.0 = INTEGER: 72
IF-MIB::ifNumber.0 = INTEGER: 4
IF-MIB::ifIndex.1 = INTEGER: 1
IF-MIB::ifIndex.2 = INTEGER: 2
IF-MIB::ifIndex.3 = INTEGER: 3
IF-MIB::ifIndex.4 = INTEGER: 4
IF-MIB::ifDescr.1 = STRING: GigabitEthernet2/0
IF-MIB::ifDescr.2 = STRING: GigabitEthernet1/0
IF-MIB::ifDescr.3 = STRING: Standby1
IF-MIB::ifDescr.4 = STRING: lo
IF-MIB::ifType.1 = INTEGER: ethernetCsmacd(6)
IF-MIB::ifType.2 = INTEGER: ethernetCsmacd(6)
IF-MIB::ifType.3 = INTEGER: other(1)
IF-MIB::ifType.4 = INTEGER: softwareLoopback(24)
IF-MIB::ifMtu.1 = INTEGER: 1500
IF-MIB::ifMtu.2 = INTEGER: 1500
IF-MIB::ifMtu.3 = INTEGER: 1500
IF-MIB::ifMtu.4 = INTEGER: 16436
IF-MIB::ifSpeed.1 = Gauge32: 1000000000
IF-MIB::ifSpeed.2 = Gauge32: 1000000000
IF-MIB::ifSpeed.3 = Gauge32: 0
IF-MIB::ifSpeed.4 = Gauge32: 0
01-15-2010 02:02 PM
Yeah, this appears to be a file engine running WAAS code which should be supportable. I am still talking with development.
01-23-2010 05:34 PM
Open a service request with TAC requesting WAAS help to change the sysObjectID. Have your engineer contact me directly, and I will put them in touch with a developer that can change the hardware cookie to get this WAE to advertise the OE-512 sysObjectID. That will make it manageable via RME.
Note: the procedure will require that you allow a WebEx session so the developer can access your device directly. Downtime will be involved.
01-26-2010 06:19 AM
Hi Jo,
Thanks for the reply, I only have one concern in that your reply implys that I have one unit, when in fact I have 7 units all with the same issue. As they where all brought at the same time.
The other issue will be getting time on each Server.
If the Developer is ok to plan the changes over a period, I will proceed.
Many thanks
Ian
01-26-2010 04:22 PM
The developer seemed to indicate that he would help given one affected device. I've asked if he can assist with the changing of seven.
01-27-2010 01:28 AM
Hi Jo,
Thought that might be the case.
Many thanks
