I have a Cisco 2911 router with one switch port module.
It it utilizes 2 of its GigabitEthernet ports to access two different WANs
we will call them WAN1(GE0/0)and WAN2(GE0/1)
i have two vlans set up on the switch ports
we will call them vlan 5 and 15
i I have a windows machine with 2 NICs
we will call them NIC1 and NIC2
NIC 1 connects to vlan 15 which connects to WAN1
NIC 2 connects to vlan 5 which connects to WAN 2
wan 1 and vlan 15 are seldom used. If I do use vlan 15 , I am not able to switch back to vlan 5 without shutting rebooting the router and vice versa.
is there a way to circumvent this issue, could I switch between WAN/vlan connections whenever I want without reloading the router. Does this issue have to do with my wan connections, my vlan settings, or my NIC?
