What Is The Best Solutions for Switching LOOPS ?
davidsmith06832
We have normal cisco topology having 4 core 8 Dist and more than 500 Access switches.I have configure switches with storm broadcast,But is there any other way to avoid loops and to know quickly where it has originated.Any help on this would be great help.expecting a great solutions for it.
cinehubapk
balaji.bandi
Not sure how your toplogy looks, what model deployed in exiting environment, good to post some topolyg and explain where you see loops expected.
in general i suggest below document help to protect most case on edge switch mistakenly patch same swith different ports - causing loops
https://community.cisco.com/t5/networking-documents/spanning-tree-loop-troubleshooting-and-safeguards/ta-p/3115040
BB
Leonid Voronkin
First of all please show us your topology. What equipment do you use?
"I have configure switches with storm broadcast,But is there any other way to avoid loops and to know quickly where it has originated."
I don't understand what exactly do you want. Storm control (if you talk about it) does not protect from loops. To avoid loops you should use xSTP family protocol for L2 design. Or you should change design to L3
________________________________________________________
Если ответ понравился, ставь звёздочку. Если ответ помог решить твою проблему, утверди его в качестве решения
