What is the difference between Login authentication using AAA and Login Local
jared.j01
I am currently studying my CCNA and I am curious as to what is the difference between configuring the below 2 options, which seem to achieve the same outcome to me.
1).
Router(config)#username user1 password pass1
Router(config)#line vty 0 15
Router(config-line)login local
Or
2).
Router(config)#aaa new-model
Router(config)#aaa authentication login LOCAL_AUTH local
Router(config-line)#login authentication LOCAL_AUTH
Thanks for your replies
When only looking at the authentication as you have configured it, you are right. Both do the same thing. But when you activate aaa new-model, you have plenty more options to control how your complete AAA is working. Most important, you can send the authentication to an external Authentication-server with RADIUS or TACACS+ or you can do Authorization where the external server controls what you are allowed to do after you have authenticated.
Don't stop after you've improved your network! Improve the world by lending money to the working poor:
http://www.kiva.org/invitedby/karsteni
Thank you very much for your reply.
Whilst I do not know much about AAA at the moment, it makes sense now.
