what the command for configure ACL to block a PC
Moshi
Deepak Kumar
Where you want to block the PC? Is it a Layer 2 or Layer 3 network where you are looking this solution? This is very little information for understanding the issue but you can use Access list as below:
ip access-list extended Block_PC
deny ip host x.x.x.x any
permit ip any any
Here x.x.x.x is the PC ip address.
Now, apply this Access-list near to the source (host) as:
ip interface xxx\x
ip access-group Block_PC in
Above example is for the router or Layer 3 device where you want to block the single host.
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
Deepak Kumar
permit ip any any
ip interface xxx\x
Deepak Kumar,
Just the router and switch but thanks for your assistance.
