Whether to support remote Telnet operation of EEM
Ru Song Fu
Hi guys:
This script can't work,I host can nelnet remote router to shutdown interaface When happens syslog access-list match.Please support.
event manager applet remote
event syslog pattern "list 100 .*11.1.1.1"
action 1.0 cli command "en"
action 2.0 cli command "telnet 10.1.1.2" pa "password"
action 3.0 cli command "cisco"
action 4.0 cli command "enable"
action 5.0 cli command "cisco"
action 6.0 cli command "confi t"
action 7.0 cli command "int g0/1"
action 8.0 cli command "sh"
action 9.0 cli command "end"
Joe Clarke
You need to keep using the pattern keyword until you're done interacting with the remote device.  For example:
action 3.0 cli command "cisco" pattern ">"
action 4.0 cli command "enable" pattern "Password:"
action 5.0 cli command "cisco" pattern "#"
Joe Clarke
Thank you answer!
