07-12-2015 09:14 AM
Hi Guys,
I have cisco prime v2.2it and I don't find controller under configure menu I am just confused how to add WLC to Cisco prime v2.2 and I have NCS license for 100 device.
Many thanks
Mohammad Saeed
Solved! Go to Solution.
07-12-2015 10:03 AM
Hi Mohammad Saeed,
You need to add the WLC the way you add anyother device like switches and routers , Under::
Inventory > Device Management > Network Devices.
check the below link:
http://www.cisco.com/c/en/us/td/docs/net_mgmt/prime/infrastructure/2-2/user/guide/pi_ug/chgdevconfig.html#pgfId-1054473
Thanks-
Afroz
***Ratings Encourages Contributors ****
07-12-2015 10:03 AM
Hi Mohammad Saeed,
Thanks-
Afroz
