Zero speed at the interface - 0 bits/sec
Hello. Look at the post until the end.
It is true that cisco counters:
do not include multicast packets?
Cat6509_ABK1#sh interfaces fa6/45
FastEthernet6/45 is up, line protocol is up (connected)
  Hardware is C6k 100Mb 802.3, address is 0011.5dbb.fc0a (bia 0011.5dbb.fc0a)
  Description: ## 100Base-TX Link satellite channel to SPB
  Internet address is 192.168.254.149/30
  MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s
  input flow-control is off, output flow-control is unsupported
  Last input 00:00:01, output 00:00:00, output hang never
  Last clearing of "show interface" counters 00:04:19
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  L2 Switched: ucast: 0 pkt, 0 bytes - mcast: 88 pkt, 42568 bytes
  L3 in Switched: ucast: 0 pkt, 0 bytes - mcast: 0 pkt, 0 bytes mcast
  L3 out Switched: ucast: 0 pkt, 0 bytes
     61 packets input, 41290 bytes, 0 no buffer
     Received 61 broadcasts (0 IP multicast)
     0 watchdog, 0 multicast, 0 pause input
     26 packets output, 2132 bytes, 0 underruns
IN 41290*8/ 259 = 1275 b/s
OUT  2132*8/259 = 66 b/s
  Last input 00:00:00, output 00:00:03, output hang never
  Last clearing of "show interface" counters 00:05:02
  L2 Switched: ucast: 0 pkt, 0 bytes - mcast: 101 pkt, 48872 bytes
     71 packets input, 48230 bytes, 0 no buffer
     Received 71 broadcasts (0 IP multicast)
     30 packets output, 2460 bytes, 0 underruns
IN 48230*8/ 302 = 1277 b/s
OUT  2460*8/302 = 65 b/s
  Last input 00:00:00, output 00:00:09, output hang never
  Last clearing of "show interface" counters 00:11:58
  L2 Switched: ucast: 0 pkt, 0 bytes - mcast: 240 pkt, 114953 bytes
     168 packets input, 114000 bytes, 0 no buffer
     Received 168 broadcasts (0 IP multicast)
     72 packets output, 5903 bytes, 0 underruns
IN 114000*8/ 718 = 1270 b/s
OUT  5903*8/ 718 = 66 b/s
  Last input 00:00:04, output 00:00:07, output hang never
  Last clearing of "show interface" counters 00:23:46
  L2 Switched: ucast: 2 pkt, 128 bytes - mcast: 479 pkt, 229842 bytes
  L3 out Switched: ucast: 1 pkt, 60 bytes
     334 packets input, 225874 bytes, 0 no buffer
     Received 333 broadcasts (0 IP multicast)
     146 packets output, 11948 bytes, 0 underruns
IN 225874*8/ 1426 = 1267 b/s
OUT  11948*8/ 1426 = 67 b/s
Hello.
There is no answer, but can anyone know
considered as speed counters on the interface of cisco?
I think this should be the number of bytes multiplied by 8 and divided by time, but something is wrong.
4695622 * 8 / 305 = 1,231,634 bit / s
five-minute counter shows the rate = 304 000 bit / s
Cat6509_ABK1#clear counters gi1/1
Clear "show interface" counters on this interface [confirm]
Cat6509_ABK1#sh interfaces gi1/1
GigabitEthernet1/1 is up, line protocol is up (connected)
   Hardware is C6k 1000Mb 802.3, address is 0009.1247.a6b0 (bia 0009.1247.a6b0)
   Description: 1000Base link  to servers PROCONT
   MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
   Full-duplex, 1000Mb/s
   input flow-control is off, output flow-control is on
   Clock mode is auto
   Last input never, output 46w6d, output hang never
   Last clearing of "show interface" counters 00:05:05
   Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
   5 minute input rate 304000 bits/sec, 158 packets/sec
   5 minute output rate 418000 bits/sec, 167 packets/sec
      29241 packets input, 4695622 bytes, 0 no buffer
      Received 39 broadcasts (6 multicast)
      33265 packets output, 13208362 bytes, 0 underruns
And maybe it bugs my IOS and will need to buy a new?
