AP wired interface speed
Peter P
We have a small number of APs (out of thousands) that have wired connections operating at 100Mbps. This would be due to bad cabling that we want to repair. I'm looking for a way to automate the discovery of AP wired interfaces running at 100Mbps. I'm not able find any API endpoints that will give me this data. Am I just missing it? I guess my other option would be SNMP and CDP info from the MS devices.
Ryan_Miles
Meraki Employee All-Star
GET/devices/{serial}/switch/ports/statuses ?
Ryan_Miles
I was just missing it! Must have mistakenly looked at the switch configure endpoint.
Ryan_Miles
Or a dashboard way would be go to the switchports list page and in the search box enter link: 100 and that should filter down to just the ports running at 100 Mbps. Make sure the Link column is enabled.
