Firmware Status via Python Module
pedro-braga
Community Member
Is it possible to get the firmware version status via API? The statuses are Good, Warning and Critical
aleabrahao
Meraki Community All-Star
No, it's not possible.
I am not a Cisco employee. My suggestions are based on documentation of Cisco, best practices and day-to-day experience.
Please, if this post was useful, leave your kudos and mark it as solved.
michalc1
HI @pedro-braga ,
Please see relevant API calls below:
To answer your question No, the API calls won't provide the status, but you can compare the current firmware version with the latest stable version. I am sure it is possible to write a script that would print out the status based on the calls above.
If you found this post helpful, please give it kudos. If it solved your problem, click "accept as solution" so that others can benefit from it.
aleabrahao
Yes but the APIs will not show if the firmware is Good, Warning and Critical. 😕
