Extended Device Info
karlwyatt
Community Member
There is more information for the devices in each network that i can pull from the dashboard than i can get using the API for instance i'm trying to GET all the device information to populate into our asset management software. Two of the things i'd like to pull is "Last Seen" and "First Seen". Both can be added to the display in Dashboard and exported to CVS or XML. Am i missing something? can i get this info with the API?
plditallo
Visitor
Karl,
I don't see an equivalent for "Last Seen" in any of the documentation, but I did come across an available additional field called lastConnected posted by @PeterJames here: (VERY) Incomplete dashboard API? - The Meraki Community
