getDevice and updateDevice doesn't work
churches_co
Community Member
I'm making a simple web-application for a client using the Meraki API. But neither of the two requests that is needed for the application is working and I cannot seem to get what is wrong. It's regarding the get-request getDevice and put-request updateDevice. All I receive is 404.
This is for the get-request:
curl -L --request GET \
--url https://api.meraki.com/api/v1/devices/XXXXXXXXXXXX \
--header 'Content-Type: application/json' \
--header 'Accept: application/json' \
--header 'X-Cisco-Meraki-API-Key: [my api key]'
and this is for the put-request:
curl -L --request PUT \
(i'm usually doing all of this in postman in then I have a body of course for the put-request)
i've also tried tried adding networks/network_id along with /sm in the path, but nothing is working and the documentation doesn't provide any answer whatsoever. And yes my key is valid, i can still get all the devices from a certain network and such. And I've made sure that the device is not in the inventory but in an actual network. Any ideas or has anyone had the same problem?
6 Replies 6
aleabrahao
Meraki Community All-Star
First, ensure you have the right network permission(which I assume you already have as you can get the organization list). Then try the below curl command to rule out any library issues.
--url https://api.meraki.com/api/v1/devices/[YOUR SERIAL NUMBER] \
--header 'X-Cisco-Meraki-API-Key: [YOUR API KEY]'
I am not a Cisco employee. My suggestions are based on documentation of Cisco, best practices and day-to-day experience.
Please, if this post was useful, leave your kudos and mark it as solved.
I may be wrong, but what you wrote is identical to mine. Is it working for you that request?
aleabrahao
Yes, the commands you are running are correct. Just check if you have the correct network permission, if the S/N and API key are correct.
If everything is ok, I suggest you open a support case.
Yeah I opened a case, thanks for the help!
Rasmus Hoffmann Birkelund
Try updating your curl command to use the Bearer authorization instead.
--url https://api.meraki.com/api/v1/devices/{serial} \
--header 'Authorization: Bearer 75dd5334bef4d2bc96f26138c163c0a3fa0b5ca6' \
https://developer.cisco.com/meraki/api-v1/get-device/
LinkedIn ::: https://blog.rhbirkelund.dk/
Like what you see? - Mark as helpful ## Did it answer your question? - Mark it as a Solution 🙂
All code examples are provided as is. Responsibility for Code execution is solely your own.
On the page @Rasmus Hoffmann Birkelund gave (or any other API page), select "Code Snippets", "Curl" to get a copy and paste example.
