Meraki users gathered using REST API not representing all users shown in Dashboard
Aiden521
Community Member
Hello
I have a program setup that will query all the networks that are returned from the Get Organization Networks API call and all the Config Templates from the Get Config Templates from an organization.
From there I am using the IDs to query for the users in each of the networks and config templates using the GET /networks/{network_id}/merakiAuthUsers.
After doing this for all the ids for the networks and config templates, I am given a number of users that is much lower than the amount that is shown in the UI dashboard for Meraki.
I am wondering if there is a way that I could potentially be missing users with the method I have specified, or if there is a more efficient way to do this such as getting all users within an organization. Any help would be greatly appreciated!
12 Replies 12
Crocker
Level 6
Level 6
Seems unlikely, but any chance your organization has more than 1000 networks? I know the Get Organization Networks API call defaults to a perpage value of 1000 if not otherwise specified. You can adjust the perpage value up to 10,000, if this happens to be the case. I don't see a similar limit documented for the other two API calls you mentioned.
Recently ran into something similar with the Get Organization Devices API call, except that one doesn't let you request more than 1000 and instead makes you learn pagination (bleh).
Aiden521
Community Member
No we have just under 50 networks in total. I also considered the issue being a pagination problem and logged the number of users being returned from each GET request when retrieving the users and the most amount of users in a given network was 106 so this wouldn't be the problem.
Jamiegprice15
Level 4
Level 4
Hi, check this code I did and see if it fits your needs. I had problems with pagination (fixed them), too. It lists all clients per network.
Merakicode/ClientScrape at main · jadexing/Merakicode (github.com)
I appreciate the input, but I am trying to get all the merakiAuthUsers and not the clients.
John-on-API
Hi @Aiden521, there is some nuance we can improve by updating the description for the operation. This operation should be described as follows, and work is underway to update the description so the docs are up to date:
List the authorized users configured under Meraki Authentication for a network (splash guest or RADIUS users for a wireless network, or client VPN users for a MX network).
While the operation name and path is a little confusing, this operation mostly operates on the authorizations of said users in the context of a specific network, and isn't true CRUD for the users themselves. So unauthorized users won't be returned in the API response.
Thanks for asking, and hopefully this helps!
Is there a method to gather all of the unauthorized users as well as the authorized ones?
I'm unclear exactly what are you trying to do.
You wrote "...given a number of users that is much lower than the amount that is shown in the UI dashboard for Meraki."
Which Dashboard page are you referring to? Is it Network->Clients?
As @John-on-API says, an 'authorized user' is related to a client device granted access via Meraki Authentication for a network.
An 'unauthorized user' is every client device that hasn't gained access that way, there is no 'user' identity there, it's just a client device.
Aiden521
Community Member
My mistake, I'll clarify a bit more. Within the dashboard after selecting "View All Networks" in the network tab, you are able to navigate to Network-Wide -> Users. It is the records here that I am attempting to capture. At the bottom of the list there is a total count of users that is given that is much more than the amount that I am able to gather using the API and doing the API calls mentioned in the original post.
Ah, now I see.
You are trying to list the page titled "User management portal", is that correct?
Aiden521
Community Member
Yes exactly! This is where the records of the users are that I am trying to capture.
Ok, currently the scope of that page is the list of Client VPN users vs. 'known' users that may have got into the list a variety of ways. I think It's really there to allow granting/removing Client VPN access, hence the lack of any rich API around it.
If you do not have any guest users (i.e. all will have an admin account), you can use https://developer.cisco.com/meraki/api-v1/get-organization-admins/ which gives you all admin users.
If there are guests, I'm not sure, if doing the https://developer.cisco.com/meraki/api-v1/get-network-meraki-auth-users/ call, which you (edit) might need to on all networks to build up the full list, isn't working then I don't think there's a way in the API.
In that case one option is to 'cheat' by making a screenscraper, or to poke around in the page code and find out the URL used by the "Download as CSV" button, then use that to grab the list as a CSV you can process.
Aiden521
Community Member
Yeah I am currently making the API call to get merakiAuthUsers for all the networks that exists within our organization but it isn't working and I am unable to retrieve all of the users with this method.
