Meraki webhook fails when using basic auth
DevMan
Community Member
I'm attempting to send Meraki event data via Webhooks to a rest endpoint that requires authentication. There does not appear to be a way for me to add headers to my Webhook configurations via the UI so I am adding basic authentication in the Webhook URL. My Webhook URL Looks like this:
https://<user>:<password>@collector.test.com/meraki
However; Meraki does not seem to like this as it always fails when I run a test. I get 401 unauthorized's as it appear Meraki is stripping out or not forwarding the auth creds. I've verified that the creds and endpoint work by doing the following curl test:
curl -X POST https://<user>:<password>@collector.test.com/meraki \
-H 'Content-Type: application/json' \
-d '{"message":"test"}'
I'd prefer to use Bearer authentication but there doesn't be a way for me to add http headers to Webhooks.
What's the best way to accomplish this?
Philip D'Ath
Meraki Community All-Star
Cisco Meraki WebHooks do not support basic authentication. Just a shared secret. Here are some examples.
https://developer.cisco.com/meraki/webhooks/#!webhook-sample-alerts
6 Replies 6
inderdeepsingh1
Level 11
Level 11
Can you share what output you are getting ?
Cisco Awarded Blogs 2020/2021 https://www.thenetworkdna.com/
I misspoke. The test just says "fail" so I don't have any context into where or why it's failing. Is there a way to see what the response code/payload is?
@DevMan : can you check this postman collection
https://documenter.getpostman.com/view/897512/SVfRtnU7?version=latest
Philip D'Ath
DexterLabora
custom headers are coming to a webhook near you...
Stay tuned for this Summer's hot updates 😉
@DexterLabora : that’s good news, thanks .. waiting
