Python Script - Rebooting Devices
Nolan H.
Level 11
Level 11
Hey everyone
I worked with a team member of mine to come up with an automated script that runs on our Ansible server that will reboot whichever Meraki access point that has 'API' at the end of its name (or really just in the name), on a weekly scheduled basis, with email reporting. This could be used I'm sure for MX or MS as well, but we are only using it for access points.
Feel free to critique. I'm not a Python person by any means, but this works great:
import json
import sys
import requests
import time
import email
import smtplib
cisco_meraki_api_Key = 'XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX'
organizationId = 'XXXXXX'
baseUrl = 'https://dashboard.meraki.com/api/v0/'
inventory_api_url = "organizations/{}/inventory".format(organizationId)
headers = {
    'X-Cisco-Meraki-API-Key': cisco_meraki_api_Key,
    'Content-Type': 'application/json'
get_inventory = requests.get(baseUrl+inventory_api_url,
                            headers=headers,
# Parse the get_inventory into json
inventory_json = get_inventory.json()
networkID = ""
serial = ""
# Opens or create a file name results
f = open('results.txt', "w+")
# loop over all the dictionaries inside inventory_json,
# if API is inside the dictionary it will get the NetworkID and the serial and then write it to the string above
for ap in inventory_json:
    try:
        if 'API' in ap['name']:
            networkID = ap['networkId']
            serial = ap['serial']
            ap_name = ap['name']
            reboot_api_call = requests.post(
                baseUrl+'/networks/{}/devices/{}/reboot'.format(networkID, serial ),
                headers=headers)
            if reboot_api_call.status_code == 200:
                print('Rebooting --->', ap_name, '---> Successful' , file=f)
                print("---------------------------------------------------",file=f)
            if reboot_api_call.status_code == 400:
                print ('Rebooting --->', ap_name, '---> Bad Request' , file=f)
            if reboot_api_call.status_code == 403:
                print ('Rebooting --->', ap_name, '---> Forbidden' , file=f)
            if reboot_api_call.status_code == 404:
                print ('Rebooting --->', ap_name, '---> Not Found' , file=f)
            if reboot_api_call.status_code == 429:
                print ('Rebooting --->', ap_name, '---> Too Many Requests' , file=f)
            time.sleep(2)
    except:
        continue
# closes the file
f.close()
# Setting up the SMTP Server
sender = '[email protected]'
receiver = '[email protected]'
smtp_server = smtplib.SMTP(host='X.X.X.X', port=25)
f = open('results.txt', "r")
# reads the information inside the file results
script_result = f.read()
message = """From: <[email protected]>
To: <[email protected]>
Subject: Meraki AP Reboot
API CODE: 200 = Successful
API CODE: 400 = Bad Request
API CODE: 403 = Forbidden
API CODE: 404 = Not Found
API CODE: 429 = Too Many Requests
""".format(script_result)
# Email execution
try:
    smtp_server.sendmail(sender, receiver, message)
    print('Successfully sent email')
except:
    print('Error: Unable to send email')
# closes the file.
f.close()
22 Replies 22
In my example it is using the keyword 'API' which must exist within the AP name for it to 'catch' it. You can change that to something else if you want. What I use is 'CRON' and i placed at the end of all my AP's for my small sites, '-CRON' for them to reboot. Been working great for me for a while now.
You can do this on a per-network basis too, so I have other sites that have AP's that start with say 'PHX' for the site code, so any AP name that has PHX will reboot for example, and if I don't want them to, I change the name to PH~X etc., to break it for that AP.
enieto
Frequent Visitor
Frequent Visitor
Thanks for the quick response.
I do use "-AP" since that should match every APs name, but it doesn't.
I changed it to just "AP", but that actually rebooted less than using "-AP".
I then changed it to "Room" since where I see most problems are in the APs that have "Room" in the name, but again, that didn't reboot every AP that had "Room" in their name.
What I also noticed when I used "-AP", it was always the same APs that were rebooted.
I just have one network, all the APs are in it.
Out of curiosity, how are you validating if the AP was rebooted or not.
enieto
Frequent Visitor
Frequent Visitor
One way is to view the txt file that is created and shows the APs that were rebooted.
I also verified if an AP was rebooted by running the script and going to a different office where the AP should have rebooted, but didn't.
DBMandrake
Community Member
Here's my own version of a bulk AP reboot script...
Because Meraki steadfastly refuse to add any sort of bulk AP reboot facility to the dashboard (I've asked them on several occasions and they say they won't consider it, and that I "shouldn't need to reboot multiple AP's" without considering the use case where yes, you do actually want to do this and every other vendor providing a way) a couple of years ago I wrote a stand alone python script to do bulk AP reboots based on device tags, so that I can reboot either all AP's in the network, or AP's with a specific tag.
As we have building name tags on our AP's to make it easier to group AP's based on building it makes it easy to reboot AP's in a certain building for example, and it would also be easy to add tags to AP's based on collections of AP's you might want to bulk reboot.
The script originally used the v0 API but when I recently tried to use it I found it was broken due to changes in the API (such as tags going from a space separated list in a single string, to an array of tags) and python Meraki module changes so I've updated it to work with the current V1 API and current Meraki python module.
#!/usr/bin/env python3
import json
import requests
import time
import meraki
import sys
import datetime
def reboot_ap(apikey, networkid, serial, suppressprint=False):
    base_url = 'https://api.meraki.com/api/v1'
    calltype = 'Device'
    posturl = '{0}/networks/{1}/devices/{2}/reboot'.format(
        str(base_url), str(networkid), str(serial))
    headers = {
        'x-cisco-meraki-api-key': format(str(apikey)),
    postdata = {
        'serial': format(str(serial))
    dashboard = requests.post(posturl, data=json.dumps(postdata),
                              headers=headers)
    print(dashboard.status_code, dashboard.text, calltype)
    return
apikey = 'api_key_here'
network_id = 'network_id_here'
reboot_all = False
cmdline = False
if len(sys.argv) > 1:
    cmdline = True
    if sys.argv[1] == '--all':
        reboot_tag = None
        reboot_all = True
    else:
        reboot_tag = sys.argv[1]
dashboard = meraki.DashboardAPI(apikey, suppress_logging=True)
deviceList = dashboard.networks.getNetworkDevices(network_id)
tag_list = []
for device in deviceList:
    new_tags = device['tags']
    for tag in new_tags:
        if not tag in tag_list:
            tag_list.append(tag)
now = datetime.datetime.now()
print(now.strftime("%H:%M:%S %d-%m-%Y"))
print('Available Tags:\n')
for tag in tag_list:
    print(tag)
if cmdline is False:
    reboot_tag = input("\nEnter Tag of APs to reboot or press enter for all APs: ")
    if not reboot_tag:
        reboot_all = True
print('\nRebooting Devices:\n')
    if reboot_tag in device['tags'] or reboot_all:
        try:
            name = device['name']
        except:
            name = 'unknown'
        print(name, device['serial'], device['lanIp'], device['tags'], '- ',end='')
        reboot_ap(apikey, network_id, device['serial'])
        time.sleep(0.5)
print()
I'm pretty rusty with Python and this was a quick expedient script to get the job done in a hurry so I'm sure the Pythonistas in the audience will be rolling their eyes at the coding... 🙂
If you run the script without command line arguments it will scan all the devices in the wireless network gathering the tags from each device to build a list of all available network device tags, these tags are then displayed. You are then prompted to either press enter (which will reboot ALL AP's in the network, be careful.. press CTRL-C if you want to back out) or enter a tag name to reboot only those AP's with that tag.
There is a 0.5 second delay between each reboot API call as if you call more than about every 0.2 seconds the API will reject the request. The success/failed result for each device will be displayed.
If you use a single command line argument '--all' can be used to reboot all AP's without prompting (for example from a cron script) or you can use a tag name to reboot devices with that Tag without prompting.
I use this script on Python 3.8 on Linux with the Meraki pip module installed. I don't think it relies on any other non-standard modules. While this version of the script hasn't been tested on Windows it should work as my original version did.
Incidentally the Meraki Python module doesn't seem to have a reboot API call, nor does the official documentation list a reboot call, hence why the actual reboot action is hand coded as an HTML query using the requests library - I simply took one of the other example requests, changed the action to reboot and it worked! 🙂
Hope someone finds this useful.
https://developer.cisco.com/meraki/api-v1/#!reboot-device
There is a Meraki Python API call now for rebooting an individual device. You just need the device's serial number.
We wrote a quick script using this API call to do an overnight reboot of our MG devices every weekend. We were finding if we didn't do a weekly reboot on some of the MG's, they'd need manual power cycles (popping the power on the PoE adapter) every couple of weeks after they randomly would drop offline.
Thanks for the heads up.
However to clarify, the /devices/{serial}/reboot API endpoint has always been there, (since the first release of the API a couple of years ago, as I was doing this already back then) but it was undocumented and it was also not exposed in the python client bindings, which is why I had to manually construct the http request to call to that endpoint in the reboot_ap() function.
I see from your link that the API endpoint is now finally documented, however I have not checked to see if there is a new version of the meraki python client bindings which add it as a proper python function call yet. (At the time of my post a month ago, it was not in the python client bindings)
In any case the script above is still working and I use it to auto reboot our AP's once a week.
IronBones
Based on DBMandrake's script I created a reboot script that I have been using:
# Script based on DBMandrake original script and edited and updated by
# Dean Warren and ChatGPT
# Github Repo: https://github.com/deawar/APReboot
import json
import requests
import os
import time
import sys
import datetime
from dotenv import load_dotenv
import meraki
def display_help():
    help_text = """
    Usage: AutoAPReboot.py [OPTIONS] <CONFIG_FILE>
    Options:
      --all           Reboot all devices in the specified networks.
      --help          Display this help message.
    Arguments:
      CONFIG_FILE     Path to the JSON configuration file containing network details.
    Description:
      This script reboots access points in multiple Meraki networks based on
      tags provided in a JSON configuration file. To use the script, ensure the
      following environment variable is defined in a .env file:
      - apiKey: Meraki API key
      The JSON configuration file should contain:
      - networkId: Meraki network ID
      - organizationId: Meraki organization ID
      - orgName: Organization name (for logging)
      - tags: List of tags to filter devices (leave empty to reboot all)
    Examples:
      Reboot all devices in all networks specified in config.json:
        python AutoAPReboot.py --all config.json
      Reboot just devices with tags specified in config.json file(can be anyname.json):
        python AutoAPReboot.py myNetwork.json
    print(help_text)
def write_log(message):
    """Log message to a file."""
    with open("reboot_log.txt", "a") as log_file:
        timestamp = datetime.datetime.now().strftime("%Y-%m-%d %H:%M:%S")
        log_file.write(f"{timestamp} - {message}\n")
# Load environment variables
load_dotenv()
apikey = os.getenv("apiKey")
# Display help if API key is missing
if not apikey:
    print("Error: Missing required environment variable `apiKey`. Please check your .env file.")
    display_help()
    sys.exit(1)
def reboot_ap(apikey, network_id, serial):
    """Reboot an access point (AP) using Meraki API."""
    post_url = f'{base_url}/networks/{network_id}/devices/{serial}/reboot'
    headers = {
        'x-cisco-meraki-api-key': apikey,
    try:
        response = requests.post(post_url, headers=headers)
        if response.status_code == 202:
            write_log(f"Reboot successful for device {serial}.")
            print(f"Reboot successful for device {serial}.")
        else:
            error_msg = f"Failed to reboot device {serial}. Status code: {response.status_code}, Response: {response.text}"
            write_log(error_msg)
            print(f"Error: {error_msg}")
    except requests.RequestException as e:
        error_msg = f"Failed to reboot device {serial}. Exception: {e}"
def reboot_devices_in_network(dashboard, network_id, tags, reboot_all):
    """Reboot devices in the specified network based on tags or all devices."""
    try:
        device_list = dashboard.networks.getNetworkDevices(network_id)
    except Exception as e:
        error_msg = f"Failed to retrieve devices for network {network_id}. Exception: {e}"
        return
    for device in device_list:
        if reboot_all or any(tag in device.get('tags', []) for tag in tags):
            name = device.get('name', 'unknown')
            print(f"Rebooting {name} ({device['serial']}) with tags {device.get('tags', [])}...")
            time.sleep(0.5)
def main():
    if '--help' in sys.argv:
        display_help()
        sys.exit(0)
    # Check if configuration file is specified
    if len(sys.argv) < 2 or (len(sys.argv) == 2 and sys.argv[1] in ['--all', '--help']):
        print("Error: Missing JSON configuration file.")
        display_help()
        sys.exit(1)
    # Determine the reboot mode and configuration file path
    reboot_all = '--all' in sys.argv
    config_file = sys.argv[-1]  # Last argument should be the JSON config file
    # Load networks from the specified JSON file
    try:
        with open(config_file, 'r') as f:
            networks = json.load(f)
        error_msg = f"Failed to load network configurations from '{config_file}'. Exception: {e}"
        sys.exit(1)
    # Initialize Meraki dashboard API
    # Iterate over each network in the JSON file and reboot devices
    for network in networks:
        network_id = network.get('networkId')
        tags = network.get('tags', [])
        org_name = network.get('orgName', 'Unknown Organization')
        if not network_id:
            error_msg = f"Skipping network due to missing networkId for organization '{org_name}'."
            continue
        print(f"\nProcessing network '{org_name}' (Network ID: {network_id})...")
        write_log(f"Processing network '{org_name}' (Network ID: {network_id}).")
if __name__ == "__main__":
    main()
that uses a .env file and takes a .json file as an argument for a list of networks and devices. My Repo is here: https://github.com/deawar/APReboot
