2 ISP Lines, each for Incoming and Outgoing Purpose
Dear Experts,
I am currently having a situation where there are 2 separate ISP lines connecting to the ASA 5512-X:
  1. Lease line with a range of fix public IP
  2. Line with dynamic public IP
My planning was to make the line 1 for incoming traffic and line 2 for outgoing traffic.
Therefore, I am seeking for your experts opinion on this design whether it is achievable or not.
ASA Version: 8.6
Sorry if similar thread already posted before.
Thank you in advance for your help.
Zul
jocamare
Level 4
Level 4
This is a no.
What you described is a difficult thing to do, it's also a bad thing to do.
It causes asymetric routing, that's a bad thing to have in a network.
You can configure load-balancing though.
The asa will need to be working in multiple-context mode.
Thank you jocamare for your reply,
I was just thinking to separate the network for incoming and outgoing traffic.
Do you think load balancer have that kind of feature? To separate the incoming and outgoing traffic?
Zul
I don't think they  have such a feature.
The problem is that it doesn't make much sense to have that, first it creates asymmetric routing, which is a bad thing to have, for several reasons.
Then, personally, i don't see what will be the use of that.
I know that you will have a dedicated interface just for one thing, but since they support both incoming and outgoing traffic at the same time it will be a waste of resources on the device.
You can always combine the resources of the interfaces in a single interface and have superior performance and redundancy.
