5525-X Fan speed slow ?
sdawson35
Hi,  We have multiple ASA 5525-X firewalls however one reports the fans running at 5300 rpm and a status of okay all our other 5525's report a fan speed of 6144.
The unit reporting 5300 rpm is running 8.6.(1)2, and the others are running 9.8.(2)17.
I have not found  a bug report for 8.6 and fan speed reporting issues so what could the problem be ?
CVPFW01# sh environment fans
Cooling Fans:
   Chassis Fans:
   Cooling Fan 1: 6144 RPM - OK
   Cooling Fan 2: 5888 RPM - OK
   Cooling Fan 3: 6144 RPM - OK
ALPFW01# sh environment fans
Cooling Fans:
   Chassis Fans:
   Cooling Fan 1: 5376 RPM - OK
   Cooling Fan 2: 5376 RPM - OK
   Cooling Fan 3: 5376 RPM - OK
Bogdan Nita
If believe the OK stands for the fan health, not for the speed.
Fan speed changes based on the temperature.
To check if the temperature is ok you can use: show environment temperature
Bogdan
