891 does not display running config below privileg level 15
I have numerous routers deployed in my network.  These are a variety of 4331, 4321, and 891.  I have set them up with a privilege level 5 login so that network technicians can view the running configuration, view interfaces, and do basic troubleshooting.  The 4331 and 4321 routers will show the running configuration at a privilege level of 5 but none of the 891 routers will.  The configuration for setting the privilege is the same for all three models.
Any suggestions of where the problem may lie?  Below is the configuration used in all three.
privilege exec level 5 ping
privilege exec level 5 show running-config view full
0 Replies 0
