Access to inside equipment from inside network using outside IP address
burleyman
Level 8
Level 8
I have been asked for the following need.
My customers wireless network has a guest and secure side. The secure side
gets an IP address in the same VLAN subnet as PC's connected directly
into a LAN switch. On their smart phones they have an app that is setup to
allow access to some equipment when you are outside the network by
going to the outside public IP address with lets say port 9200 and it translates to
an internal IP address of the piece of equipment and it works fine.
So let's say the external IP address is 1.1.1.1, which is the outside interface of the ASA, and I am outside the network and
go to 1.1.1.1:9200 it will take me to 10.30.1.28 and that is working fine.
Now here is my question, They want the ability to go from the inside subnet of 10.30.1.0/24
and type 1.1.1.1:9200 and have it do the same thing as it would if they were outside the network.
How would I do this? or could I do this?
So basically they want these three things to work...
Outside the network they go to 1.1.1.1:9200 and it gets to 10.30.1.28 (I have this working now)
and
Inside the network they want to go to 10.30.1.28:9200 and also get to 10.30.1.28 ( This is also working now.)
and
Inside the network they want to go to 1.1.1.1:9200 and get to 10.30.1.28 <--- This is what they want to get working.
Mike
kcrane2
It's called hairpin nat and configuring it is explained pretty well here:
http://mike-knight.blogspot.com/2013/06/asa-84-and-hairpin-nat.html
That said, I try to avoid it wherever I can.   Completely inefficient to send internal traffic through the firewall then back through it to the internal network.
Thanks I will check it out. I am running 8.2 and I found that on the web link as well. Stay tuned.
Mike
Jon Marshall
Mike
You may also want to use this link to a thread on the same thing as, for me at least, it seems to explain it a bit better -
https://supportforums.cisco.com/discussion/11878621/insideinside-nat-asa-91
Jon
Thanks I will check it out and post my config to see if it looks good.
Mike
