ACL for traffic Passing between Transparent Firewall and Routed FW
mahesh18
Level 6
Level 6
Hi Everyone.
If we had this topology
Server is connected to Switch 1 and switch 1 connects switch 2  layer connection and switch 2 has connection to transparent ASA.
Now this transparent ASA  has connection to switch 3 and Switch 3 has connection to another ASA2    then  the internet.
For above traffic flow do we need ACL at both transparent ASA  and ASA2?
Mahesh
5 Accepted Solutions
Julio Carvajal
Hello Mahesh,
Same concept will apply on transparent mode for l3 traffic ( if traffic from lower to higher needs to be allowed then create the ACL) (From higher to lower no need)
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
After this traffic passes through another ASA  thats in routed  mode.
Do i need to apply ACL  there also?
If the traffic goes on that one from lower to higher: Yes , as well.
Note: The only L3 traffic while being on L2 mode that I am aware of that needs an ACL from higher to lower is for multicast traffic
Julio Carvajal
Yes, it can access any port unless you deny it via an ACL,
Julio Carvajal
Hello Mahesh,
No, unless there was an ACL already,
Was there an ACL already ( on the highest security level interface)?
Julio Carvajal
Hello Mahesh,
Exactly,as I said on one of my previous posts:
Remember to rate all of the helpful posts
Julio Carvajal
15 Replies 15
Julio Carvajal
Hello Mahesh,
Julio Carvajal
Hi Julio,
As transparent is layer 2 firewall.Traffic there is coming from lower to higher security.
i will apply ACL there.
Mahesh
Julio Carvajal
Hi Julio,
So i need two ACL  one on transparent and other on second ASA  right?
thanks
mahesh
Hello Mahesh,
You got it
Julio Carvajal
Hi Julio,
I just did  some change on Network where  Traffic was passing from transparent Fw and Routed FW.
I put ACL   on transparent FW  to allow traffic  on port 80.
But Routed Fw was denying traffic  on port 80.
But from  Routed Mode traffic was entering on high security  interface and leaving on  Lower security interface.
So ACL  at Routed  mode was denying the traffic going to destination on port 80 even though  flow was from high to low.
when we say that traffic can flow from high to low security  interface does it also mean that we can access any ports also?
Mahesh
Julio Carvajal
Hi Julio,
To make this work i  had to config ACL  on Routed ASA to allow traffic on port 80.
Even though flow was from  high to low security.
Is this default behaviour?So in  short i had to config 2 ACL  each on transparent and Routed ASA  to make this work.
Mahesh
Hello Mahesh,
Julio Carvajal
Hi Julio,
On interface from high to low security there was no ACL.
I had to put  ACL  to allow traffic from higher to lower on port 80.
Mahesh
Hello Mahesh,
That's not required,
You are missing something,
Can you share the configuration without the ACL (make sure it does not work before posting it here)
Julio Carvajal
Hi Julio,
I dig deeper and found that there was ACL  on Routed ASA  which was denying the traffic.
Seems earlier  as it was denying the traffic thats why i need to  put the second ACL  on routed  ASA  also.
Now it makes sense why i need 2 ACL  each on transparent  and routed ASA to make this  work.
Hope you agree with this.
MAhesh
Hello Mahesh,
Julio Carvajal
Hi Julio,
Yes there was an  ACL  on higher to lower denying IP traffic.
Seems last time i did not understand what you said.
But asking you  more questions helped me to  understand better now.
Best regards
Mahesh
