ACL syntax problem
Colin Higgins
Level 7
Level 7
I have a ASA services modules in a 6509-E that is giving me issues with ragards to ACL syntax
Let's say I have a KMS server at 192.168.20.10
I want to allow all hosts to reach this server at port tcp 1688
so I do
object-group network KMS-SERVERS
host 192.168.20.10
then
access-list KMS-ACCESS-IN extended permit tcp any object-group KMS-SERVERS eq 1688
problem is, it WILL NOT take the "eq 1688"
this was a valid command in other IOS versions. Why isn't it working now?
that is typically the case if the object-group is not available. Thats the reason I asked what you *really* configured on your box.
Don't stop after you've improved your network! Improve the world by lending money to the working poor:
http://www.kiva.org/invitedby/karsteni
If you found this post helpful, please give it Kudos. If my answer solves your problem, please click Accept as Solution so others can benefit from it.
Is that really what you configured? Your object-group doesn't look like that what you show here is what you did on your ASA.
Please verify and show the exact terminal-output.
well that is my question
the command
access-list KMS-ACCESS-IN extended permit tcp any host 192.168.20.10 eq 1688
will work
will not
I don't get any options after the object group
this used to work
