AIP-SSM not firing any sigs - Analysis Engine is Busy
raga.fusionet
Level 4
Level 4
Hello guys,
I have installed an AIP-SSM module on my ASA's lab and I cant get it to fire any signatures. I do see traffic going thru the interfaces which makes me think it's not an issue with the ASA Config, however I dont see any sigs even if I generate events that would fire one such a TCP port scan or bitorrent.
I have assigned an interface to the vs0 and configured the basic stuff but still I'm not getting any hits. One thing I noticed is this unsual message on the logs:
vError: eventId=1341365101856715019  vendor=Cisco  severity=error
  originator:
    hostId: sensor
    appName: collaborationApp
    appInstanceId: 452
  time: Jul 04, 2012 20:21:32 UTC  offset=0  timeZone=UTC
  errorMessage: Analysis Engine is Busy Processing Stage 3 of 97 at Step 0 of 1
Messages, like this one, in the category - ct to sensorApp timed out - were logged 1 times in the last 0 seconds.  name=errUnclassified
Here's the IDS config and a show int:
sh interfaces Gi
GigabitEthernet     GigabitEthernet0/0  GigabitEthernet0/1
RFNET-IPS# sh interfaces GigabitEthernet0/1
MAC statistics from interface GigabitEthernet0/1
   Interface function = Sensing interface
   Description =
   Media Type = backplane
   Default Vlan = 0
   Inline Mode = Unpaired
   Pair Status = N/A
   Hardware Bypass Capable = No
   Hardware Bypass Paired = N/A
   Link Status = Up
   Admin Enabled Status = Enabled
   Link Speed = Auto_1000
   Link Duplex = Auto_Full
   Missed Packet Percentage = 0
   Total Packets Received = 2545022
   Total Bytes Received = 1683855948
   Total Multicast Packets Received = 0
   Total Broadcast Packets Received = 0
   Total Jumbo Packets Received = 0
   Total Undersize Packets Received = 0
   Total Receive Errors = 0
   Total Receive FIFO Overruns = 0
   Total Packets Transmitted = 2544496
   Total Bytes Transmitted = 1683341358
   Total Multicast Packets Transmitted = 0
   Total Broadcast Packets Transmitted = 0
   Total Jumbo Packets Transmitted = 0
   Total Undersize Packets Transmitted = 0
   Total Transmit Errors = 0
   Total Transmit FIFO Overruns = 0
RFNET-IPS# sh configuration
! Current configuration last modified Wed Jul 04 16:01:57 2012
! Version 7.0(8)
! Host:
!     Realm Keys          key1.0
! Signature Definition:
!     Signature Update    S654.0   2012-06-25
service interface
exit
service authentication
exit
service event-action-rules rules0
exit
service host
network-settings
host-ip 172.16.10.235/24,172.16.10.1
host-name RFNET-IPS
telnet-option disabled
access-list 172.16.10.0/24
access-list 172.16.14.0/24
dns-primary-server enabled
address 172.16.10.237
exit
dns-secondary-server disabled
dns-tertiary-server disabled
exit
time-zone-settings
offset -360
standard-time-zone-name GMT-06:00
exit
ntp-option enabled-ntp-unauthenticated
ntp-server 209.114.111.1
exit
exit
service logger
exit
service network-access
exit
service notification
exit
service signature-definition sig0
exit
service ssh-known-hosts
exit
service trusted-certificates
exit
service web-server
exit
service anomaly-detection ad0
exit
service external-product-interface
exit
service health-monitor
event-retrieval-policy
enable false
exit
exit
service global-correlation
exit
service aaa
exit
service analysis-engine
virtual-sensor vs0
physical-interface GigabitEthernet0/1
exit
exit
Any suggestions would be appreciated
Thanks!
raga.fusionet
Level 4
Level 4
Either this is a little weird or I'm looking at the wrong place. If I do a show statistics virtual-sensor I seem to be getting some hits on different sigs:
Per-Signature SigEvent count since reset
            Sig 6403.1 = 6
            Sig 6409.1 = 17
            Sig 6409.2 = 2
            Sig 20059.1 = 1453
            Sig 21619.1 = 2
            Sig 23782.2 = 2
            Sig 30260.1 = 3
However If I go to the IDM, Monitoring, Events, Event Viewer all I see is health messages from the sensor itself, not signatures.
Any ideas? Thanks.
You may edit the above firing signatures. Add Event Action to "produce-alert.
Sawan Gupta
Thanks & Regards, Sawan Gupta
Raga,
Hope you are doing great. Have you tried with the very basic ones? 2000 and 2004 for ICMP traffic? Enable them and put the action to produce alert.
Then go to Monitoring and set an IP logging. Use the IP addresses that you are trying to ping to make a packet capture (ip logging ), start it, send the ping and then stop the IP logging, after that the IP logging either will dissapear (meaning the packets are not getting to the virtual sensor) or appear but the action is not taken.
On the home page you can also see the state of the analysis engine, it normall stucks in compiling signatures, but analysis engine should be back.
We can take it from there.
Mike
Mike
