allow sql communication between Inside to DMZ interfaces
Abdulrakib
Community Member
Dear ALL
i have one ASA5510 firewall i configure it as outside and inside and dmz , i have one web server at DMZ i have als one SQL server at inside , i have to transfer the data netween the inside SQL server amd the DMZ SQL client the firewall did not allow that i need the suitable commands to allow this traffic through the firewall can you help me
sachinverma
You need to allow port 1433 for sql from dmz to inside.Also please clarify what data are you transferring.
cheers
Sachin
access-list DMZ_ACL permit tcp host A.B.C.D host W.X.Y.Z eq 1433
A.B.C.D is in the DMZ
W.X.Y.Z is in the Inside network
access-group DMZ_ACL in interface DMZ
