An error occurred while configuring OSPF for FTD using FDM
xiaolj
Visitor
What is the reason for this error?
"The instance does not match the template it is using"
8 Replies 8
you disable the log-adj in step 2 so no need anymore step3
remove step 3 and check again
MHM
thank you  for reply! As you said, I've done the steps, but it's still the same problem.
Add new object with correct two steps and then check.
MHM
Still the same problem
router ospf 1
 log-adj-changes disable
OR
router ospf 1
 log-adj-changes enable
  log-adj-changes details
MHM
xiaolj
Visitor
Problem solved:
Set the browser's default language to English and make the FDM login page in English
Many many many thanks for update me
have a nice day
MHM
