anomaly guard logs (Can't connect to managment module; SYSTEM IS NOT FULLY OPERATIONAL: Connection refused)
borusantelekom
when i want to configure guard module but some logs displaying. what is the problem and what am i do.
logs below thats;
admin@GUARD#conf terminal
Management module is busy. Please try again in 10 seconds
admin@GUARD-conf#interface eth1
admin@GUARD-conf-if-eth1#no sh
admin@GUARD-conf-if-eth1#no shutdown
To complete the configuration change you must reload the software
Are you sure you want to reload? Type 'yes' to reload
yes
reloading...
null
Shutting down interface giga2:  [  OK  ]
Message from syslogd@localhost at Mon May 10 08:52:05 2010 ...
localhost admin: RHInit FATAL: Bad CFE version ( 34). This version requires version 31  /* what does it mean
admin@GUARD#sh running-config
Can't write to socket
Error getting reactivate-after-reboot information
thanks.
Jennifer Halim
Normally this issue is resolved by upgrading it to the latest release (6.1.6). Here is the release notes for your reference:
http://www.cisco.com/en/US/docs/interfaces_modules/services_modules/anomaly_guard/v6.1/release/note/R6_1GMod.html
