ASA 5505 8.2(1) - Poor WAN connection speed
jgeorge
To sum it up the ASA is maxing out at 7MB down on a 25MB connection. The connection was tested with the ASA removed and the connection is fine.
This popped out at me the most but i'm not sure what it means:
12884935775 switch ingress policy drops for eth 0/0
ciscoasa# show interface
Interface Vlan1 "inside", is up, line protocol is up
  Hardware is EtherSVI, BW 100 Mbps, DLY 100 usec
        MAC address 0025.84ba.a5bf, MTU 1500
        IP address 192.192.192.1, subnet mask 255.255.255.0
  Traffic Statistics for "inside":
        60970690 packets input, 13913244351 bytes
        58976961 packets output, 51852996074 bytes
        11661619 packets dropped
      1 minute input rate 73 pkts/sec,  17085 bytes/sec
      1 minute output rate 77 pkts/sec,  58339 bytes/sec
      1 minute drop rate, 4 pkts/sec
      5 minute input rate 184 pkts/sec,  71247 bytes/sec
      5 minute output rate 140 pkts/sec,  100504 bytes/sec
      5 minute drop rate, 4 pkts/sec
Interface Vlan2 "outside", is up, line protocol is up
        IP address 64.132.143.181, subnet mask 255.255.255.240
  Traffic Statistics for "outside":
        59393878 packets input, 55428940778 bytes
        49439745 packets output, 11588292732 bytes
        671362 packets dropped
      1 minute input rate 70 pkts/sec,  57386 bytes/sec
      1 minute output rate 62 pkts/sec,  15718 bytes/sec
      1 minute drop rate, 0 pkts/sec
      5 minute input rate 131 pkts/sec,  99810 bytes/sec
      5 minute output rate 174 pkts/sec,  70422 bytes/sec
      5 minute drop rate, 0 pkts/sec
Interface Vlan12 "Guest1", is up, line protocol is up
        IP address 10.0.0.254, subnet mask 255.255.255.0
  Traffic Statistics for "Guest1":
        25319316 packets input, 3816960570 bytes
        3983553 packets output, 3862554401 bytes
        20598136 packets dropped
      1 minute input rate 6 pkts/sec,  698 bytes/sec
      1 minute output rate 0 pkts/sec,  136 bytes/sec
      5 minute input rate 6 pkts/sec,  674 bytes/sec
      5 minute output rate 0 pkts/sec,  101 bytes/sec
Interface Ethernet0/0 "", is up, line protocol is up
  Hardware is 88E6095, BW 100 Mbps, DLY 100 usec
        Full-Duplex(Full-duplex), 100 Mbps(100 Mbps)
        Available but not configured via nameif
        MAC address 0025.84ba.a5b7, MTU not set
        IP address unassigned
        59625610 packets input, 56589417802 bytes, 0 no buffer
        Received 121934 broadcasts, 0 runts, 0 giants
        205101 input errors, 205101 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
        0 L2 decode drops
        49439776 packets output, 12647462703 bytes, 0 underruns
        0 late collisions, 0 deferred
        0 input reset drops, 0 output reset drops
        0 rate limit drops
        0 switch egress policy drops
Interface Ethernet0/1 "", is down, line protocol is down
        Auto-Duplex, Auto-Speed
        MAC address 0025.84ba.a5b8, MTU not set
        27929 packets input, 2231730 bytes, 0 no buffer
        Received 1401 broadcasts, 0 runts, 0 giants
        0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
        0 L2 decode drops
        1215 switch ingress policy drops
        4146822 packets output, 691162685 bytes, 0 underruns
        0 rate limit drops
Interface Ethernet0/2 "", is up, line protocol is up
        Auto-Duplex(Full-duplex), Auto-Speed(100 Mbps)
        MAC address 0025.84ba.a5b9, MTU not set
        108154469 packets input, 20904268305 bytes, 0 no buffer
        Received 17076444 broadcasts, 0 runts, 0 giants
        150631 input errors, 1 CRC, 0 frame, 150629 overrun, 0 ignored, 0 abort
        0 L2 decode drops
        12884961778 switch ingress policy drops
        99512019 packets output, 57258966359 bytes, 0 underruns
        0 rate limit drops
Interface Ethernet0/3 "", is up, line protocol is up
        MAC address 0025.84ba.a5ba, MTU not set
        53107701 packets input, 7048981307 bytes, 0 no buffer
        Received 25152462 broadcasts, 0 runts, 0 giants
        75668 input errors, 0 CRC, 0 frame, 75667 overrun, 0 ignored, 0 abort
        0 L2 decode drops
        17179903698 switch ingress policy drops
        44326368 packets output, 4312679805 bytes, 0 underruns
        0 rate limit drops
Interface Ethernet0/5 "", is up, line protocol is up
        MAC address 0025.84ba.a5bc, MTU not set
        192436 packets input, 20479294 bytes, 0 no buffer
        Received 0 broadcasts, 0 runts, 0 giants
        0 L2 decode drops
        8589967618 switch ingress policy drops
        39213895 packets output, 6080350462 bytes, 0 underruns
        0 rate limit drops
Interface Ethernet0/6 "", is up, line protocol is up
        MAC address 0025.84ba.a5bd, MTU not set
        3121302 packets input, 498409602 bytes, 0 no buffer
        Received 235583 broadcasts, 0 runts, 0 giants
        0 L2 decode drops
        8589969007 switch ingress policy drops
        42570272 packets output, 9835351746 bytes, 0 underruns
        0 rate limit drops
6 Replies 6
mirober2
Hi Jason,
Is Ethernet0/0 the port that connects to the Internet? If so, there are a large number of CRC errors on that interface:
This is usually caused by a speed/duplex mismatch. The settings should match whatever is set on the device the ASA connects to. Try changing the speed and duplex to auto and then do 'clear interface' to reset the error counters:
interface e0/0
   speed auto
   duplex auto
clear interface
Hope that helps.
-Mike
Thanks for pointing that out. I forgot to mention at one point for troublshooting I tried to chage the interface speed and I belive that is where the CRC errors are coming from. I cleared the stats and since then no more CRC errors are being viewed. The issue is still there but the CRC were caused by earlier troublshooting.
Would you please paste your running configuration? I want to know if you have any of the following things:
HTTP filter options
HTTP inspection
QoS configured
SSC card involved
Also, are you connected directly to the ASA? Can you try to download a file directly connected to the Internet router and then do the same when connected behind the ASA firewall?
If you are able to do that test, please start wireshark when doing the download, then when connected behind the firewall, please start a packet capture when doing the same download on the inside and outside interface of the firewall, so we can analyze the Input/Output rates.
Cheers
Mike
Mike
I only have remote access to the ASA currently but I will get all the information I can till I can get physical access. Connected directly to the ISP modem the speed is 20Mb down connected directly the ASA the speed is aorund 7MB down.
Below is the new show interface that had the stats cleared last night and let run till this morning.
        1699136 packets input, 365889334 bytes
        1582846 packets output, 1330972492 bytes
        255633 packets dropped
      1 minute input rate 192 pkts/sec,  18512 bytes/sec
      1 minute output rate 255 pkts/sec,  309449 bytes/sec
      5 minute input rate 44 pkts/sec,  8631 bytes/sec
      5 minute output rate 41 pkts/sec,  25659 bytes/sec
        1705308 packets input, 1348744583 bytes
        1671154 packets output, 745037104 bytes
        20975 packets dropped
      1 minute input rate 252 pkts/sec,  310646 bytes/sec
      1 minute output rate 206 pkts/sec,  19326 bytes/sec
      5 minute input rate 37 pkts/sec,  25546 bytes/sec
      5 minute output rate 36 pkts/sec,  8173 bytes/sec
        640441 packets input, 451206607 bytes
        235123 packets output, 22489484 bytes
        255533 packets dropped
      1 minute input rate 5 pkts/sec,  569 bytes/sec
      1 minute output rate 0 pkts/sec,  36 bytes/sec
      5 minute input rate 5 pkts/sec,  630 bytes/sec
      5 minute output rate 0 pkts/sec,  137 bytes/sec
        1715924 packets input, 1387217073 bytes, 0 no buffer
        Received 3079 broadcasts, 0 runts, 0 giants
        0 L2 decode drops
        6170 switch ingress policy drops
        1674502 packets output, 780669552 bytes, 0 underruns
        0 rate limit drops
        0 packets input, 0 bytes, 0 no buffer
        0 L2 decode drops
        0 packets output, 0 bytes, 0 underruns
        0 rate limit drops
        1799538 packets input, 413345564 bytes, 0 no buffer
        Received 320388 broadcasts, 0 runts, 0 giants
        0 L2 decode drops
        446 switch ingress policy drops
        1586035 packets output, 1364705821 bytes, 0 underruns
        0 rate limit drops
        399454 packets input, 50953863 bytes, 0 no buffer
        Received 300177 broadcasts, 0 runts, 0 giants
        0 L2 decode drops
        1247 switch ingress policy drops
        32731 packets output, 3812121 bytes, 0 underruns
        0 rate limit drops
Interface Ethernet0/4 "", is up, line protocol is up
        MAC address 0025.84ba.a5bb, MTU not set
        0 L2 decode drops
        419587 packets output, 53105944 bytes, 0 underruns
        0 rate limit drops
        7231 packets input, 770618 bytes, 0 no buffer
        0 L2 decode drops
        6199 switch ingress policy drops
        420466 packets output, 52963068 bytes, 0 underruns
        0 rate limit drops
        346535 packets input, 425288639 bytes, 0 no buffer
        Received 17359 broadcasts, 0 runts, 0 giants
        0 L2 decode drops
        6202 switch ingress policy drops
        630532 packets output, 78303975 bytes, 0 underruns
        0 rate limit drops
Interface Ethernet0/7 "", is up, line protocol is up
        MAC address 0025.84ba.a5be, MTU not set
        5578 packets input, 425978 bytes, 0 no buffer
        Received 2457 broadcasts, 0 runts, 0 giants
        0 L2 decode drops
        420710 packets output, 53253787 bytes, 0 underruns
        0 rate limit drops
Below is the running-config:
: Saved
ASA Version 8.2(1)
hostname ciscoasa
enable password x
passwd x encrypted
names
name 192.192.192.6 A-192.192.192.6 description Buffalo Terastation
interface Vlan1
nameif inside
security-level 100
ip address 192.192.192.1 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address 64.x.x.181 255.255.255.240
interface Vlan12
nameif Guest1
security-level 50
ip address 10.0.0.254 255.255.255.0
interface Ethernet0/0
switchport access vlan 2
speed 100
duplex full
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
switchport access vlan 12
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
ftp mode passive
clock timezone EST -5
clock summer-time EDT recurring
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
object-group service RDP tcp
port-object eq 3389
object-group service UDP4500 udp
description UDP4500
port-object eq 4500
object-group service DM_INLINE_TCP_1 tcp
port-object eq www
port-object eq https
port-object eq imap4
port-object eq smtp
access-list inside_access_in extended permit tcp host 192.192.192.3 any eq smtp
access-list inside_access_in extended permit tcp host 192.192.192.5 any eq smtp
access-list inside_access_in extended deny tcp any any eq smtp
access-list inside_access_in extended permit ip any any
access-list inside_access_in extended permit tcp host 192.192.192.12 any eq smtp
access-list inside_access_in extended permit tcp host A-192.192.192.6 any eq ftp
access-list outside_access_in extended permit tcp any host 64.x.x.179 eq www
access-list outside_access_in extended permit udp any any eq ntp
access-list outside_access_in extended permit tcp any host 64.x.x.179 eq https
access-list outside_access_in extended permit tcp any host 64.x.x.179 object-group RDP
access-list outside_access_in extended permit tcp any host 64.x.x.179 eq 3390 log disable
access-list outside_access_in extended permit tcp any host 64.x.x.178 eq smtp
access-list outside_access_in extended permit tcp any host 64.x.x.180 object-group DM_INLINE_TCP_1
access-list outside_access_in extended permit udp any host 64.x.x.185 eq isakmp
access-list outside_access_in extended permit udp any host 64.x.x.185 object-group UDP4500
access-list outside_access_in extended permit esp any host 64.x.x.185
access-list outside_access_in extended permit tcp any host 64.x.x.179 eq ftp
access-list outside_access_in extended permit tcp any host 64.x.x.179 eq ftp-data
access-list DefaultRAGroup_splitTunnelAcl standard permit 192.192.192.0 255.255.255.0
access-list inside_nat0_outbound extended permit ip 192.192.192.0 255.255.255.0 192.168.10.0 255.255.255.0
access-list Guest1_access_in extended permit ip any any
pager lines 20
logging enable
logging timestamp
logging trap debugging
logging asdm informational
logging host inside 192.192.192.5
logging permit-hostdown
mtu inside 1500
mtu outside 1500
mtu Guest1 1500
ip local pool VPN_POOL 192.168.10.100-192.168.10.200 mask 255.255.255.0
no failover
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
global (outside) 1 interface
global (outside) 2 64.x.x.185 netmask 255.0.0.0
global (outside) 3 64.x.x.178 netmask 255.0.0.0
nat (inside) 0 access-list inside_nat0_outbound
nat (inside) 3 192.192.192.5 255.255.255.255
nat (inside) 2 192.192.192.12 255.255.255.255
nat (inside) 1 172.20.10.0 255.255.255.0
nat (inside) 1 192.192.192.0 255.255.255.0
nat (Guest1) 1 10.0.0.0 255.255.255.0
static (inside,outside) tcp 64.x.x.179 www 192.192.192.5 www netmask 255.255.255.255
static (inside,outside) udp interface ntp 192.192.192.5 ntp netmask 255.255.255.255
static (inside,outside) tcp 64.x.x.179 https 192.192.192.5 https netmask 255.255.255.255
static (inside,outside) tcp 64.x.x.179 3389 192.192.192.5 3389 netmask 255.255.255.255
static (inside,outside) tcp 64.x.x.179 3390 192.192.192.27 3389 netmask 255.255.255.255
static (inside,outside) tcp 64.x.x.178 smtp 192.192.192.3 smtp netmask 255.255.255.255
static (inside,outside) tcp 64.x.x.179 ftp A-192.192.192.6 ftp netmask 255.255.255.255
static (inside,outside) tcp 64.x.x.179 ftp-data A-192.192.192.6 ftp-data netmask 255.255.255.255
static (inside,outside) udp 64.x.x.185 isakmp 192.192.192.12 isakmp netmask 255.255.255.255
static (inside,outside) udp 64.x.x.185 4500 192.192.192.12 4500 netmask 255.255.255.255
static (inside,outside) tcp 64.x.x.180 https 192.192.192.37 https netmask 255.255.255.255
static (inside,outside) tcp 64.x.x.180 www 192.192.192.37 www netmask 255.255.255.255
static (inside,outside) tcp 64.x.x.180 smtp 192.192.192.37 smtp netmask 255.255.255.255
static (inside,Guest1) 64.x.x.179 192.192.192.5 netmask 255.255.255.255
access-group inside_access_in in interface inside
access-group outside_access_in in interface outside
access-group Guest1_access_in in interface Guest1
route outside 0.0.0.0 0.0.0.0 64.x.x.177 1
route inside 172.20.10.0 255.255.255.0 192.192.192.10 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
dynamic-access-policy-record DfltAccessPolicy
aaa-server RADIUS protocol radius
aaa-server RADIUS (inside) host 192.192.192.226
key srdh228
radius-common-pw srdh228
url-server (inside) vendor websense host 192.192.192.23 timeout 10 protocol UDP version 4
filter url http 0.0.0.0 0.0.0.0 0.0.0.0 0.0.0.0 allow
http server enable
http 192.168.1.0 255.255.255.0 inside
http 192.192.192.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set TRANS_ESP_3DES_SHA esp-3des esp-sha-hmac
crypto ipsec transform-set TRANS_ESP_3DES_SHA mode transport
crypto ipsec transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto ipsec transform-set L2TP esp-3des esp-md5-hmac
crypto ipsec transform-set L2TP mode transport
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set pfs group1
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set transform-set ESP-AES-128-SHA
crypto map outside_map 65535 ipsec-isakmp dynamic SYSTEM_DEFAULT_CRYPTO_MAP
crypto map outside_map interface outside
crypto isakmp enable outside
crypto isakmp policy 10
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
telnet 192.192.192.0 255.255.255.0 inside
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd auto_config outside
dhcpd address 10.0.0.100-10.0.0.200 Guest1
dhcpd dns 216.136.95.2 interface Guest1
dhcpd enable Guest1
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
group-policy DefaultRAGroup internal
group-policy DefaultRAGroup attributes
dns-server value 192.192.192.5
vpn-tunnel-protocol IPSec l2tp-ipsec
split-tunnel-policy tunnelspecified
split-tunnel-network-list value DefaultRAGroup_splitTunnelAcl
default-domain value lan.tuggleduggins.com
username cisco password x encrypted privilege 15
tunnel-group DefaultRAGroup general-attributes
address-pool VPN_POOL
authentication-server-group RADIUS
default-group-policy DefaultRAGroup
strip-realm
strip-group
tunnel-group DefaultRAGroup ipsec-attributes
pre-shared-key *
tunnel-group DefaultRAGroup ppp-attributes
authentication ms-chap-v2
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect dns
  inspect icmp
  inspect ipsec-pass-thru
service-policy global_policy global
prompt hostname context
Cryptochecksum:5ed15c9e53bbb3a6d23e4b2d5d9c17ba
: end
asdm location A-192.192.192.6 255.255.255.255 inside
asdm location 64.x.x.180 255.255.255.255 inside
Ok, let me know when you have time to do the things physically, meantime, is there a possibility to add a filter URL except for a host and then that you try to do the test again from the host you did the except?
Mike
Mike
In regards to:
I removed filter url http 0.0.0.0 0.0.0.0 0.0.0.0 0.0.0.0 allow
so
no filter url http 0.0.0.0 0.0.0.0 0.0.0.0 0.0.0.0 allow
after this was done the speed went from 5Mb down 2Mb Up to 19Mb down 6Mb up.
Could anyone explain why this was slowing down WAN connection?
