ASA 5505 problem?
laposilaszlo
Level 3
Level 3
What is the diference between the
ASA5505-50-BUN-K8 and
ASA5505-SEC-BUN-K9.
It is only a licensing problem or the hardware is diferent.
Thank you
laszlo
ajagadee
Laszlo,
Below is the difference, I hope it helps. And as far as I understand, it is only a licensing difference and not hardware.
ASA5505-50-BUN-K8
Cisco ASA 5505 50-User Bundle includes 8-port Fast Ethernet switch, 10 IPsec VPN peers, 2 SSL VPN peers, DES license
ASA5505-SEC-BUN-K8
Cisco ASA 5505 Unlimited-User Security Plus Bundle includes 8-port Fast Ethernet switch, 25 IPsec VPN peers, 2 SSL VPN peers, DMZ, stateless Active/Standby high availability,
DES license
http://www.cisco.com/en/US/prod/collateral/vpndevc/ps6032/ps6094/ps6120/prod_qas0900aecd805a1273.html
Arul
** Please rate all helpful posts **
Can you tell me the part number for the upgrade?
Thank you,
laszlo
Laszlo,
ASA5505-50-BUN-K8 and ASA5505-SEC-BUN-K8 are both part numbers. You can refer the URL that I had posted earlier.
So, if you are planning to upgrade from ASA5505-50-BUN-K8 to ASA5505-SEC-BUN-K8, then you need to order the part number ASA5505-SEC-BUN-K8.
I hope it helps.
Arul
