ASA 5505 Problem
At the boot up of the ASA 5505 device, the  status LED remains red, i have used a console port to connect but nothing seems to be responding.
i dont know if it's a hardware issue or software, please any help is greatly appreciated.
Device description
Cisco ASA 5505 Series
SN : JMX1131Z2JG
Abdelnour MOUSSAOUI
Network Administrator.
Hi Moussaoui,
It could be. If you have any spare RAM then you could do that.  If RAM is the issue then generally it shows atleast something on the console. That is th reason i asked if even a single line shows up on the screen then it could be RAM issue.
Akshay Rastogi
Akshay Rastogi
Hi Moussaoui,
I believe you have already reloaded it.
If it doesn't show up anything in the console (not even a single line; i believe console cable is fine)  then open a tac case. It might be a hardware issue.
Akshay Rastogi
Hi Akshay,
i already did all what you say (relaod, cable fine) nothing show up on console ports. after some research on the internet some people said it is RAM issue, is it possible ?.
best regard.
Hi Moussaoui,
Akshay Rastogi
Hello Akshay,
just to give you a feedback, i have just raplaced a new RAM and it worked.
thank you for you assistance.
best regards
