ASA 5505 ssl work ipsec does not
roger perkin
Level 2
Level 2
I am trying to configure an IPSEC vpn on an ASA5505
I setup an SSL vpn and it works fine, I can browse to the https: address log in and connnect to servers
However when I try to setup the ipsec client access vpn it will not connect and I am getting the errors below
I used the wizard for the initial configuration
Looks like the inital IKE is being blocked or dropped?
%ASA-7-710005: UDP request discarded from my external IP/35781 to external:ASA-external/500
%ASA-7-710005: UDP request discarded from my external IP/35781 to external:ASA-external/137
Roger
Try
nat (inside,outside) 1 source static 192.168.100.0  192.168.100.0 destination static  VPN_172 VPN_172
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
10 Replies 10
Julio Carvajal
Hello
do you have the
crypto isakamp enable  outside configured?
What version are you running?
Julio Carvajal
crypto ikev2 enable external
crypto ikev1 enable external
Running version 8.4(1)
The ssl works perfectly
I then configured the IPSEC using the wizard and it wont' connect?
Scratching my head a bit
Roger
Hello Roger,
Can you share the configuration so I can take a quick look at it
Julio Carvajal
Problem nearly fixed, I rebooted the firewall and I am now able to log in
However traffic is only flowing one way lots of encrypted packets but 0 decrypted
Also my split tunnel does not seem to be working.
I will get the config into this post soon
Roger
Then we will need to check the confi
Julio Carvajal
Ok, I am getting this error when pinging an internal host from the connected vpn client
VPN client is on 172.16.24.2 internal host is on 192.168.100.37
%ASA-5-305013: Asymmetric NAT rules matched for forward and reverse flows; Connection for icmp src external:172.16.24.2 dst internal:192.168.100.37 (type 8, code 0) denied due to NAT reverse path failure
object network obj-192.168.50.10
host 192.168.50.10
object network obj-192.168.50.20
host 192.168.50.20
object network obj-192.168.50.21
host 192.168.50.21
object network obj_any
subnet 0.0.0.0 0.0.0.0
object network obj_any-01
object network obj-0.0.0.0
host 0.0.0.0
object network NETWORK_OBJ_10.10.1.0_28
subnet 10.10.1.0 255.255.255.240
object network vpn_clients
subnet 192.168.199.0 255.255.255.0
object network 192.168.100.0
subnet 192.168.100.0 255.255.255.0
object network NETWORK_OBJ_192.168.199.0_24
object network VPN_172
subnet 172.16.24.0 255.255.255.0
object-group service RDP tcp
port-object eq 3389
object-group service SQL tcp
port-object eq 1433
object-group service RDP-SQL tcp
group-object RDP
group-object SQL
access-list outside_in extended permit udp any any log
access-list network_10_access_in extended permit ip interface internal any
access-list external_access_in extended permit ip object NETWORK_OBJ_192.168.199.0_24 interface internal
access-list external_access_in extended permit tcp any any inactive
access-list from_outside extended permit icmp any any log
access-list from_outside extended permit icmp any any echo
access-list split_VPN_Split standard permit 192.168.100.0 255.255.255.0
access-list external_access_in_1 extended permit ip object NETWORK_OBJ_192.168.199.0_24 192.168.100.0 255.255.255.0
access-list external_access_in_1 extended permit ip object VPN_172 192.168.100.0 255.255.255.0
pager lines 24
nat (internal,external) source static any any destination static NETWORK_OBJ_10.10.1.0_28 NETWORK_OBJ_10.10.1.0_28
nat (internal,external) source static 192.168.100.0 192.168.100.0 destination static NETWORK_OBJ_192.168.199.0_24 NETWORK_OBJ_192.168.199.0_24
nat (internal,external) source static any any destination static NETWORK_OBJ_192.168.199.0_24 NETWORK_OBJ_192.168.199.0_24
nat (internal,external) static 192.168.0.81
nat (internal,external) static 192.168.0.230
nat (internal,external) static 192.168.0.231
nat (internal,external) dynamic interface
nat (internal,external) dynamic obj-0.0.0.0
access-group network_10_access_in in interface internal
access-group external_access_in_1 in interface external
route external 0.0.0.0 0.0.0.0 4.5.6.7.1 1
route internal 10.10.10.0 255.255.255.255 192.168.100.1 1
Try
Julio Carvajal
Thanks for that, we are now one step closer!
Now getting this error
%ASA-4-313004: Denied ICMP type=0, from laddr 172.16.24.2 on interface external to 192.168.100.37: no matching session
Thanks for your replies, I have marked the nat as the correct answer, after much head stratching, I have now realised the porblem.
This is another firewall added to the network.
The default gateway of the client I am pinging is another firewall so the ping is going in and then going  back to the main firewall.
My issue lies on the internal network.
Roger
Hello Roger,
Glad to know that I could help,
Have a great day
Julio Carvajal
