ASA 5505 Using Class C Address on LAN ?? Can you help.
russ
Hi, I have a Cisco ASA 5505, running 9.2(3) / 7.3(3).
Our ISP gave us a routable Class C Address (254) usable.
I would like to use these public routable addresses on the LAN (INSIDE) interface of the ASA.
Since these addresses are routable, I don't want to use NAT.
The LAN clients / servers:
Clients: (5) Windows  Clients, & 1 Mail Server.
I need all LAN (Inside clients) to access internet for browsing.
I need to block all traffic coming from the Internet to Windows Clients, but allow Port 3389 (Remote Desktop), and port 25 for SMTP mail.
There is also a Site to Site VPN to another ASA 5505 (same IOS/ASDM).
What is the best way to do this? Static Identity NAT, or NAT Exemption ??
I would like to avoid NAT, completely since I have the luxury of 254 routable public IP Addresses
Thanks.
Marvin Rhoads
You can use the addresses natively - just don't put any NAT rules in the config.
You will have to subdivide the /24 into subnets so that the ASA knows which ones to route out the Internet-facing interface and which go to the inside network.
Then just put the security policy you want into the access-list.
