ASA 5510 failing PCI scan due to using SSL 3.0 and TLS 1.0
Brian Beaman
The live IP for our ASA that is used for management and AnyConnect VPN is failing the PCI scan. Shows the IP using SSL 3.0 and TLS 1.0. I had a look and it seems like SSL 3.0 and TLS 1.0 are my only options in the drop down menu. Is there anyway to get newer standards or get rid of SSL and run TLS 1.2?
My knowledge in security is limited so sorry in advance.
0 Replies 0
