ASA 5510 NAT-T connection problem
alankong_cisco
We have ASA 5510 running 8.3(2). There was no problem if one single NATed client made VPN connection to the ASA 5510. However, when there were more than one NATed clients made VPN connecttions, either the new client got no connection or the old connection got kicked out. Could this be a bug?
Thank you.
Alan
My Configruation:
: Saved
ASA Version 8.3(2)
hostname ciscoasa
domain-name x.x.x.x
enable password Q/xxwnwRB encrypted
passwd 2KxxKYOU encrypted
names
interface Ethernet0/0
nameif outside
security-level 0
ip address x.x.x.203 255.255.252.0
! No Network Connection
interface Ethernet0/1
nameif inside
security-level 100
ip address 192.168.3.2 255.255.255.0
interface Ethernet0/2
shutdown
no nameif
no security-level
no ip address
interface Ethernet0/3
shutdown
no nameif
no security-level
no ip address
interface Management0/0
nameif management
security-level 100
management-only
boot system disk0:/asa832-k8.bin
ftp mode passive
clock timezone HKST 8
dns server-group DefaultDNS
domain-name x.x.x.x
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
object network OBJ_GENERIC_ALL
subnet 0.0.0.0 0.0.0.0
object network OBJ_SPECIFIC_10_4_5_0
subnet 10.4.5.0 255.255.255.0
object network vpn-nat
pager lines 24
logging asdm informational
mtu outside 1500
mtu inside 1500
mtu management 1500
ip local pool vpn_address 10.4.5.10-10.4.5.200
no failover
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-635.bin
no asdm history enable
arp timeout 14400
nat (any,outside) dynamic interface
route outside 0.0.0.0 0.0.0.0 x.x.x.254 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
dynamic-access-policy-record DfltAccessPolicy
aaa-server vpn-aaa-gp protocol radius
reactivation-mode depletion deadtime 5
aaa-server vpn-aaa-gp (outside) host x.x.x.152
key *****
authentication-port 1812
accounting-port 1813
aaa authentication ssh console LOCAL
http server enable
http 192.168.1.0 255.255.255.0 management
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
sysopt connection preserve-vpn-flows
crypto ipsec transform-set TRANS_ESP_3DES_SHA esp-3des esp-sha-hmac
crypto ipsec transform-set TRANS_ESP_3DES_SHA mode transport
crypto ipsec transform-set ESP_AES_128_MD5 esp-aes esp-md5-hmac
crypto ipsec transform-set ESP_AES_128_MD5 mode transport
crypto ipsec transform-set ESP_AES_128_SHA esp-aes esp-sha-hmac
crypto ipsec transform-set ESP_AES_128_SHA mode transport
crypto ipsec transform-set ESP_AES_192_MD5 esp-aes-192 esp-md5-hmac
crypto ipsec transform-set ESP_AES_192_MD5 mode transport
crypto ipsec transform-set ESP_AES_256_MD5 esp-aes-256 esp-md5-hmac
crypto ipsec transform-set ESP_AES_256_MD5 mode transport
crypto ipsec transform-set ESP_AES_256_SHA esp-aes-256 esp-sha-hmac
crypto ipsec transform-set ESP_AES_256_SHA mode transport
crypto ipsec transform-set ESP_AES_192_SHA esp-aes-192 esp-sha-hmac
crypto ipsec transform-set ESP_AES_192_SHA mode transport
crypto ipsec transform-set TRANS_ESP_3DES_MD5 esp-3des esp-md5-hmac
crypto ipsec transform-set TRANS_ESP_3DES_MD5 mode transport
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto dynamic-map DL2TP_MAP 10 set transform-set ESP_AES_128_MD5 ESP_AES_128_SHA ESP_AES_256_MD5 ESP_AES_256_SHA TRANS_ESP_3DES_SHA TRANS_ESP_3DES_MD5 ESP_AES_192_MD5 ESP_AES_192_SHA
crypto dynamic-map DL2TP_MAP 10 set reverse-route
crypto map L2TP_MAP 200 ipsec-isakmp dynamic DL2TP_MAP
crypto map L2TP_MAP interface outside
crypto isakmp identity address
crypto isakmp enable outside
crypto isakmp policy 10
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
crypto isakmp policy 12
encryption 3des
hash md5
group 2
lifetime 86400
crypto isakmp policy 14
encryption des
hash sha
group 2
lifetime 86400
crypto isakmp policy 16
encryption des
hash md5
group 2
lifetime 86400
crypto isakmp nat-traversal 300
telnet timeout 5
ssh scopy enable
ssh x.x.33.6 255.255.255.255 outside
ssh timeout 5
console timeout 0
l2tp tunnel hello 100
dhcpd address 192.168.1.2-192.168.1.254 management
dhcpd enable management
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
ntp server 137.189.11.63
webvpn
group-policy vpn_policy internal
group-policy vpn_policy attributes
dns-server value x.x.x.50 x.x.x.11
vpn-tunnel-protocol l2tp-ipsec
username admin password IpmYxxxxxUl encrypted
username gordon password XPxxxxxxMNn1 encrypted
tunnel-group DefaultRAGroup general-attributes
address-pool vpn_address
authentication-server-group vpn-aaa-gp
authorization-server-group vpn-aaa-gp
accounting-server-group vpn-aaa-gp
default-group-policy vpn_policy
strip-group
tunnel-group DefaultRAGroup ipsec-attributes
pre-shared-key *****
tunnel-group DefaultRAGroup ppp-attributes
authentication pap
no authentication chap
no authentication ms-chap-v1
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
service-policy global_policy global
prompt hostname context
Cryptochecksum:b6560db8166e8c1ba9a61a243ec75fa3
: end
ciscoasa#
Nicolas Fournier
Hi Alan,
You are correct, this is a bug I opened some time ago:
CSCtj03800 Second L2TP session disconnects first one if NATed to the same public IP.
You can have a look at it's description from the following link:
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCtj03800
As you can see there, it is fixed as from 8.3(2.8).
Nicolas
