08-25-2011 01:57 AM - edited 03-11-2019 02:16 PM
I am having trouble with our ASA5510.
After upgrading the internal memory from 256 MB to 1 GB and upgrading the firmware to 8.4.2 we are experiencing that the ASA is running out of 1550 byte blocks. When that happens it is not possible to connect to the ASA by ADSM or SSH and new VPN IPSEC tunnels are not coming up.
The only way I know how to fix this is to reload the ASA. This is happening every 2 to 3 days.
In the free blocks graph one can see that there is a loss of about 20 blocks per 10 minutes.
What are the steps I can take to find out what is causing this?
Or is it a bug maybe ?
Geert Veenstra
08-25-2011 02:09 AM
Hi Geert,
I wodl suggest you to open a TAC case for it, since this might require detailed investigation into it, even if it is hitting a bug. Outputs needs to be collected from the firewall to ensure any memory leaks on the ASA.
Varun
12-11-2011 09:42 AM
it's hitting a bug - bud ID CSCto774092. look in bug toolkit
12-11-2011 01:17 PM
Hello Geert,
Just to add to what Alon said, it is definetly a bug, I have worked on some cases with this issue after an upgrade to
8.4.2,
I will give you some more information on this on Monday,
Have a wonderful Sunday.
Julio!!
12-12-2011 10:23 AM
Hello Alon,
Here is the exact bug ID you are facing:CSCto74092
ASA 1550 byte block depletion causing traffic failure
The bug is still open so I would recommend you to downgrade to 8.4.1(11) because at this moment the bug still being worked on.
07-03-2013 07:33 AM
Hello I am having this problem too and am on version 9.1(1)8
I have opened up 3 separate TAC cases it’s not fixed yet...
It appears to be a re-occurring issue as there has been quite a few iOS releases that have fixed this issue.
Mine happens every week so not as often but means I have to reboot the ASA twice a week out of hours to stop it crashing inside of office hours.
Any suggestions on where to start looking?
07-03-2013 07:58 AM
Think we had this bug in ASA5585-X SSP20 running 8.4(2)
It was running around 100 Security Contexts.
One of them had a "logging" configurations that pointed to a Syslog server. However the interface IP address was missing from the interface. (Probably configuration was "dropped" to the firewall which had overlapping IP address with other context and command was ignored)
This seemed to cause the ASA to eventually run out of resources and reboot
To my understanding nothing more was done in our case other than configure the IP address under the interface. Though I would imagine that this shouldnt be happening even if the IP address was missing from the interface and there was an existing "logging" configuration.
Somehow I think this probably is not what you are facing.
- Jouni
07-03-2013 08:06 AM
Hello Jouni,
Syslogging was disabled before we started having the issue :-( just checked all the firewall rules have logging disbaled as well as I only turn the logging on for troubble shooting when something is getting blocked.
Just went through the logging settings and they all seem ok, 4096 Bytes for the internal buffer (100 queue) and only the ASDM log is enabled and set to Notifications
Kind Regards
Paul
07-03-2013 08:08 AM
All interfaces and sub interfaces have IP addresses assigned.
07-03-2013 09:02 AM
Call me sad but I've downloaded a copy of the packets using
show blocks old dump | b size 1550
There doesn't seem to be a single type of traffic, IE I've got DFS Replication packets going over a VPN and normal HTTP traffic getting stuck (***** = name of the DFS server) and there was a few others I've seen but no real link between them.
Packet contents:
0xa69fcb24: 00 00 00 00 | ....
0xa69fcb34: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xa69fcb44: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xa69fcb54: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xa69fcb64: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xa69fcb74: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xa69fcb84: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xa69fcb94: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xa69fcba4: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xa69fcbb4: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xa69fcbc4: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xa69fcbd4: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xa69fcbe4: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xa69fcbf4: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xa69fcc04: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xa69fcc14: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 a4 4c | ...............L
0xa69fcc24: 11 77 00 1c 58 43 a4 4c 11 77 00 1c 58 43 56 e1 | .w..XC.L.w..XCV.
0xa69fcc34: a4 4c 11 77 0e 3f 08 00 45 00 00 80 b2 2c 40 00 | .L.w.?..E....,@.
0xa69fcc44: 40 32 c0 10 b0 38 c0 3a 05 66 a4 4c 11 77 0e 3c | @2...8.:.f.L.w.<
0xa69fcc54: 00 0c 76 c5 c6 f8 81 00 00 14 08 00 45 00 00 54 | ..v.........E..T
0xa69fcc64: 00 00 40 00 40 01 44 07 0a 02 0a e5 c0 a8 21 13 | ..@.@.D.......!.
0xa69fcc74: 08 00 d8 f9 cf 6d 00 24 c3 d0 d3 51 c4 4e 09 00 | .....m.$...Q.N..
0xa69fcc84: 08 09 0a 0b 0c 0d 0e 0f 10 11 12 13 14 15 16 17 | ................
0xa69fcc94: 18 19 1a 1b 1c 1d 1e 1f 20 21 22 23 24 25 26 27 | ........ !"#$%&'
0xa69fcca4: 28 29 2a 2b 2c 2d 2e 2f 30 31 32 33 34 35 36 37 | ()*+,-./01234567
0xa69fccb4: 23 4e 3c fe d5 1c ff d2 00 0c 18 81 1e 2b 0c 7a | #N<..........+.z
0xa69fccc4: a4 14 bd 27 3a 43 fd 39 c5 7a 01 fc 68 59 1d 33 | ...':C.9.z..hY.3
0xa69fccd4: 31 37 d5 b5 e0 de f8 58 e9 ab 37 2d f1 30 55 4b | 17.....X..7-.0UK
0xa69fcce4: 9f a3 7d 5a 04 a3 1b da 2e 55 8d 75 72 c4 f2 c6 | ..}Z.....U.ur...
0xa69fccf4: 4a 40 9a 47 d4 80 6b 33 a4 dc 64 34 35 64 30 33 | J@.G..k3..d45d03
0xa69fcd04: 31 30 62 39 62 61 34 34 32 63 62 61 62 65 39 22 | 10b9ba442cbabe9"
0xa69fcd14: 2c 22 74 69 6d 65 22 3a 31 33 37 32 33 30 39 38 | ,"time":13723098
0xa69fcd24: 30 30 30 30 30 2c 22 70 73 74 22 3a 22 4a 75 6e | 00000,"pst":"Jun
0xa69fcd34: 65 20 32 36 2c 20 32 30 31 33 20 31 30 3a 31 30 | e 26, 2013 10:10
0xa69fcd44: 3a 30 30 20 50 4d 20 50 44 54 22 2c 22 6d 65 73 | :00 PM PDT","mes
0xa69fcd54: 73 61 67 65 22 3a 22 54 68 65 20 70 72 6f 62 6c | sage":"The probl
0xa69fcd64: 65 6d 20 77 69 74 68 20 47 6f 6f 67 6c 65 20 56 | em with Google V
0xa69fcd74: 6f 69 63 65 20 73 68 6f 75 6c 64 20 62 65 20 72 | oice should be r
0xa69fcd84: 65 73 6f 6c 76 65 64 2e 20 57 65 20 61 70 6f 6c | esolved. We apol
0xa69fcd94: 6f 67 69 7a 65 20 66 6f 72 20 74 68 65 20 69 6e | ogize for the in
0xa69fcda4: 63 6f 6e 76 65 6e 69 65 6e 63 65 20 61 6e 64 20 | convenience and
0xa69fcdb4: 74 68 61 6e 6b 20 79 6f 75 20 66 6f 72 20 79 6f | thank you for yo
0xa69fcdc4: 75 72 20 70 61 74 69 65 6e 63 65 20 61 6e 64 20 | ur patience and
0xa69fcdd4: 63 6f 6e 74 69 6e 75 65 64 20 73 75 70 70 6f 72 | continued suppor
0xa69fcde4: 74 2e 22 2c 22 74 79 70 65 22 3a 33 2c 22 72 65 | t.","type":3,"re
0xa69fcdf4: 73 6f 6c 76 65 64 22 3a 74 72 75 65 2c 22 70 72 | solved":true,"pr
0xa69fce04: 65 6d 69 65 72 22 3a 66 61 6c 73 65 7d 5d 2c 22 | emier":false}],"
0xa69fce14: 61 76 61 69 6c 44 61 74 61 22 3a 7b 22 73 65 72 | availData":{"ser
0xa69fce24: 76 69 63 65 41 76 61 69 6c 44 61 74 61 4d 61 70 | viceAvailDataMap
0xa69fce34: 22 3a 7b 7d 7d 2c 22 74 72 61 6e 73 6c 61 74 69 | ":{}},"translati
0xa69fce44: 6f 6e 73 22 3a 7b 22 4e 4f 4e 5f 53 4c 41 5f 44 | ons":{"NON_SLA_D
0xa69fce54: 45 53 43 52 49 50 54 49 4f 4e 22 3a 22 50 72 6f | ESCRIPTION":"Pro
0xa69fce64: 64 75 63 74 73 20 6e 6f 74 20 63 6f 76 65 72 65 | ducts not covere
0xa69fce74: 64 20 62 79 20 5c 75 30 30 33 63 61 20 69 64 5c | d by \u003ca id\
0xa69fce84: 75 30 30 33 64 5c 22 61 61 64 2d 6c 69 6e 6b 2d | u003d\"aad-link-
0xa69fce94: 73 6c 61 5c 22 20 68 72 65 66 5c 75 30 30 33 64 | sla\" href\u003d
0xa69fcea4: 5c 22 68 74 74 70 3a 2f 2f 77 77 77 2e 67 6f 6f | \"http://www.goo
0xa69fceb4: 67 6c 65 2e 63 6f 6d 2f 61 70 70 73 2f 69 6e 74 | gle.com/apps/int
0xa69fcec4: 6c 2f 65 6e 2f 74 65 72 6d 73 2f 73 6c 61 2e 68 | l/en/terms/sla.h
0xa69fced4: 74 6d 6c 5c 22 5c 75 30 30 33 65 47 6f 6f 67 6c | tml\"\u003eGoogl
0xa69fcee4: 65 20 41 70 70 73 20 53 65 72 76 69 63 65 20 4c | e Apps Service L
0xa69fcef4: 65 76 65 6c 20 41 67 72 65 65 6d 65 6e 74 5c 75 | evel Agreement\u
0xa69fcf04: 30 30 33 63 2f 61 5c 75 30 30 33 65 22 2c 22 54 | 003c/a\u003e","T
0xa69fcf14: 4f 44 41 59 53 5f 53 54 41 54 55 53 22 3a 22 54 | ODAYS_STATUS":"T
0xa69fcf24: 6f 64 61 79 5c 75 30 30 32 37 73 20 53 74 61 74 | oday\u0027s Stat
0xa69fcf34: 75 73 22 2c 22 47 4f 4f 47 4c 45 5f 48 4f 4d 45 | us","GOOGLE_HOME
0xa69fcf44: 22 3a 22 47 6f 6f 67 6c 65 20 48 6f 6d 65 22 2c | ":"Google Home",
0xa69fcf54: 22 4c 4f 43 41 4c 5f 54 49 4d 45 53 22 3a 22 41 | "LOCAL_TIMES":"A
0xa69fcf64: 6c 6c 20 74 69 6d 65 73 20 61 72 65 20 73 68 6f | ll times are sho
0xa69fcf74: 77 6e 20 69 6e 20 79 6f 75 72 20 6c 6f 63 61 6c | wn in your local
0xa69fcf84: 20 74 69 6d 65 7a 6f 6e 65 20 75 6e 6c 65 73 73 | timezone unless
0xa69fcf94: 20 6f 74 68 65 72 77 69 73 65 20 6e 6f 74 65 64 | otherwise noted
0xa69fcfa4: 2e 22 2c 22 53 4c 41 5f 44 45 53 43 52 49 50 54 | .","SLA_DESCRIPT
0xa69fcfb4: 49 4f 4e 22 3a 22 50 72 6f 64 75 63 74 73 20 63 | ION":"Products c
0xa69fcfc4: 6f 76 65 72 65 64 20 62 79 20 5c 75 30 30 33 63 | overed by \u003c
0xa69fcfd4: 61 20 69 64 5c 75 30 30 33 64 5c 22 61 61 64 2d | a id\u003d\"aad-
0xa69fcfe4: 6c 69 6e 6b 2d 73 6c 61 5c 22 20 68 72 65 66 5c | link-sla\" href\
0xa69fcff4: 75 30 30 33 64 5c 22 68 74 74 70 3a 2f 2f 77 77 | u003d\"http://ww
0xa69fd004: 77 2e 67 6f 6f 67 6c 65 2e 63 6f 6d 2f 61 70 70 | w.google.com/app
0xa69fd014: 73 2f 69 6e 74 6c 2f 65 6e 2f 74 65 72 6d 73 2f | s/intl/en/terms/
0xa69fd024: 73 6c 61 2e 68 74 6d 6c 5c 22 5c 75 30 30 33 65 | sla.html\"\u003e
0xa69fd034: 47 6f 6f 67 6c 65 20 41 70 70 73 20 53 65 72 76 | Google Apps Serv
0xa69fd044: 69 63 65 20 4c 65 76 65 6c 20 41 67 72 65 65 6d | ice Level Agreem
0xa69fd054: 65 6e 74 5c 75 30 30 33 63 2f 61 5c 75 30 30 33 | ent\u003c/a\u003
0xa69fd064: 65 20 61 6e 64 20 5c 75 30 30 33 63 61 20 69 64 | e and \u003ca id
0xa69fd074: 5c 75 30 30 33 64 5c 22 61 61 64 2d 6c 69 6e 6b | \u003d\"aad-link
0xa69fd084: 2d 74 73 73 67 5c 22 20 68 72 65 66 5c 75 30 30 | -tssg\" href\u00
0xa69fd094: 33 64 5c 22 68 74 74 70 3a 2f 2f 77 77 77 2e 67 | 3d\"http://www.g
0xa69fd0a4: 6f 6f 67 6c 65 2e 63 6f 6d 2f 61 70 70 73 2f 69 | oogle.com/apps/i
0xa69fd0b4: 6e 74 6c 2f 65 6e 2f 74 65 72 6d 73 2f 74 73 73 | ntl/en/terms/tss
0xa69fd0c4: 67 2e 68 74 6d 6c 5c 22 5c 75 30 30 33 65 54 65 | g.html\"\u003eTe
0xa69fd0d4: 63 68 6e 69 63 61 6c 20 53 75 70 70 6f 72 74 20 | chnical Support
0xa69fd0e4: 53 65 72 76 69 63 65 20 47 75 69 64 65 6c 69 6e | Service Guidelin
0xa69fd0f4: 65 73 5c 75 30 30 33 63 2f 61 5c 75 30 30 33 65 | es\u003c/a\u003e
0xa69fd104: 22 2c 22 53 45 52 56 49 43 45 5f 4f 55 54 41 47 | ","SERVICE_OUTAG
0xa69fd114: 45 22 3a 22 53 65 72 76 69 63 65 20 6f 75 74 61 | E":"Service outa
0xa69fd124: 67 65 22 2c 22 4c 45 47 45 4e 44 5f 4c 4f 4e 47 | ge","LEGEND_LONG
0xa69fd134: 22 3a 22 54 68 65 20 66 6f 6c 6c | ":"The foll
Packet contents:
0xa6a02884: 00 00 00 00 | ....
0xa6a02894: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xa6a028a4: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xa6a028b4: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xa6a028c4: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xa6a028d4: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xa6a028e4: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xa6a028f4: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xa6a02904: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xa6a02914: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xa6a02924: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xa6a02934: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xa6a02944: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xa6a02954: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xa6a02964: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xa6a02974: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 a4 4c | ...............L
0xa6a02984: 11 77 00 1c 58 43 a4 4c 11 77 00 1c 58 43 56 e1 | .w..XC.L.w..XCV.
0xa6a02994: a4 4c 11 77 0e 3f 08 00 45 a0 00 78 7e 35 00 00 | .L.w.?..E..x~5..
0xa6a029a4: 40 32 0c 2d b0 38 d4 be d9 c8 a4 4c 11 77 0e 3c | @2.-.8.....L.w.<
0xa6a029b4: 00 0c 76 c5 c6 f8 81 00 00 14 08 00 45 00 00 54 | ..v.........E..T
0xa6a029c4: 00 00 40 00 40 01 44 06 0a 02 0a e5 c0 a8 21 14 | ..@.@.D.......!.
0xa6a029d4: 08 00 00 cb dc 30 00 1a e5 e8 d3 51 6d ac 09 00 | .....0.....Qm...
0xa6a029e4: 08 09 0a 0b 0c 0d 0e 0f 10 11 12 13 14 15 16 17 | ................
0xa6a029f4: 18 19 1a 1b 1c 1d 1e 1f 20 21 22 23 24 25 26 27 | ........ !"#$%&'
0xa6a02a04: 28 29 2a 2b 2c 2d 2e 2f 30 31 32 33 34 35 36 37 | ()*+,-./01234567
0xa6a02a14: 87 5a 37 3b 61 19 34 7e 31 85 f3 f2 72 6c a2 e9 | .Z7;a.4~1...rl..
0xa6a02a24: 52 72 e0 4e 39 25 78 3b b8 38 a8 49 c8 35 ba 89 | Rr.N9%x;.8.I.5..
0xa6a02a34: 19 c6 ce 0b 4b 49 f0 39 d7 e2 d4 e4 cf b2 34 c4 | ....KI.9......4.
0xa6a02a44: 4f 53 dd 67 5c 51 72 f6 dd 6d da f5 e6 c7 5c 20 | OS.g\Qr..m....\
0xa6a02a54: 4a 77 a1 ae f7 db d0 c0 cc 8b 93 d3 c4 61 6f 30 | Jw...........ao0
0xa6a02a64: c3 6c ae 26 30 4f 8e 61 f2 b6 63 8b 78 58 ea eb | .l.&0O.a..c.xX..
0xa6a02a74: 23 d0 77 2a de e6 91 d0 3c 3d 56 93 16 5b 72 1f | #.w*....<=V..[r.
0xa6a02a84: 41 89 70 7e 62 86 a8 ab 99 33 96 e3 d7 44 60 0e | A.p~b....3...D`.
0xa6a02a94: b6 2d 3c 16 5f 80 7b 6e 95 85 aa 7c d0 ab 08 44 | .-<._.{n...|...D
0xa6a02aa4: 02 bc 90 f9 87 8d 12 a0 ed 3c aa f7 ba 47 f4 81 | .........<...G..
0xa6a02ab4: 9d 69 80 3b 3e c7 51 19 1a e6 08 00 00 00 00 00 | .i.;>.Q.........
0xa6a02ac4: 00 00 00 00 00 00 00 00 29 00 00 00 0a 00 00 80 | ........).......
0xa6a02ad4: 03 08 00 00 00 39 00 00 00 60 00 00 00 00 0b 00 | .....9...`......
0xa6a02ae4: 00 00 ff ff b5 00 00 00 02 08 00 00 00 8f 00 00 | ................
0xa6a02af4: 00 00 49 44 00 08 00 00 00 00 00 00 00 00 00 00 | ..ID............
0xa6a02b04: 00 00 00 36 00 00 00 0a 00 00 80 03 08 00 00 00 | ...6............
0xa6a02b14: 41 01 00 00 60 00 00 00 00 0b 00 00 00 ff ff b5 | A...`...........
0xa6a02b24: 00 00 00 02 08 00 00 00 8f 00 00 00 f9 00 00 00 | ................
0xa6a02b34: 11 03 00 00 00 00 00 00 00 00 73 74 72 69 6e 67 | ..........string
0xa6a02b44: 00 13 00 00 00 01 00 04 00 00 00 00 00 00 00 04 | ................
0xa6a02b54: 00 00 00 00 52 65 74 75 72 6e 56 61 6c 75 65 00 | ....ReturnValue.
0xa6a02b64: 00 75 69 6e 74 33 32 00 13 00 00 00 01 00 04 00 | .uint32.........
0xa6a02b74: 00 00 00 00 00 00 11 00 00 00 0a 00 00 80 03 08 | ................
0xa6a02b84: 00 00 00 8f 01 00 00 00 75 69 6e 74 33 32 00 00 | ........uint32..
0xa6a02b94: 6f 75 74 00 13 00 00 00 01 00 04 00 00 00 00 00 | out.............
0xa6a02ba4: 00 00 1c 00 00 00 0a 00 00 80 03 08 00 00 00 8f | ................
0xa6a02bb4: 01 00 00 97 01 00 00 00 0b 00 00 00 ff ff 00 00 | ................
0xa6a02bc4: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xa6a02bd4: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xa6a02be4: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xa6a02bf4: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xa6a02c04: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xa6a02c14: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xa6a02c24: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xa6a02c34: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xa6a02c44: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xa6a02c54: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xa6a02c64: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xa6a02c74: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xa6a02c84: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xa6a02c94: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xa6a02ca4: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xa6a02cb4: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xa6a02cc4: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xa6a02cd4: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xa6a02ce4: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xa6a02cf4: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xa6a02d04: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xa6a02d14: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xa6a02d24: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xa6a02d34: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
0xa6a02d44: 00 00 00 00 00 00 00 00 00 00 00 0c 00 00 00 00 | ................
0xa6a02d54: 00 5f 5f 00 00 00 80 1c 00 00 00 1c 04 00 00 00 | .__.............
0xa6a02d64: 0b 00 00 00 ff ff 29 04 00 00 02 08 00 00 00 36 | ......)........6
0xa6a02d74: 04 00 00 00 49 6d 70 6c 65 6d 65 6e 74 65 64 00 | ....Implemented.
0xa6a02d84: 00 44 65 73 63 72 69 70 74 69 6f 6e 00 00 52 65 | .Description..Re
0xa6a02d94: 74 72 69 65 76 65 73 20 74 68 65 20 63 75 72 72 | trieves the curr
0xa6a02da4: 65 6e 74 20 76 65 72 73 69 6f 6e 20 76 65 63 74 | ent version vect
0xa6a02db4: 6f 72 20 63 68 61 69 6e 20 6f 66 20 74 68 69 73 | or chain of this
0xa6a02dc4: 20 6d 65 6d 62 65 72 00 00 46 65 6e 63 65 00 81 | member..Fence..
0xa6a02dd4: 0a 00 00 05 00 4d 53 2d 46 50 30 31 00 00 52 4f | .....*********..RO
0xa6a02de4: 4f 54 5c 4d 69 63 72 6f 73 6f 66 74 44 66 73 00 | OT\MicrosoftDfs.
0xa6a02df4: 1d 00 00 00 00 ff ff ff ff 00 00 00 00 04 00 00 | ................
0xa6a02e04: 00 04 00 00 00 00 00 00 00 00 00 00 80 0c 00 00 | ................
0xa6a02e14: 00 00 00 00 00 00 00 00 80 2f 0a 00 00 00 00 00 | ........./......
0xa6a02e24: 00 00 08 00 00 00 04 00 00 00 0f 00 00 00 0e 00 | ................
0xa6a02e34: 00 00 00 0b 00 00 00 ff ff 03 00 00 00 a1 03 00 | ................
0xa6a02e44: 00 74 04 00 00 d2 04 00 00 bf 05 00 00 2a 00 00 | .t...........*..
0xa6a02e54: 00 2a 03 00 00 15 ff ff ff ff ff ff ff 0c 06 00 | .*..............
0xa6a02e64: 80 00 5f 5f 50 41 52 41 4d 45 54 45 52 53 00 00 | ..__PARAMETERS..
0xa6a02e74: 61 62 73 74 72 61 63 74 00 11 00 00 00 00 00 00 | abstract........
0xa6a02e84: 00 00 00 00 00 00 00 04 00 00 00 00 4d 6f 64 65 | ............Mode
0xa6a02e94: 00 00 75 69 6e 74 38 00 11 00 00 | ..uint8....
