ASA 5516-X CLI 9.8 - need help getting port-forward working
JossEllis
I have an ASA-5516-X that I'm migrating an old 5510 to. As an example I have the below, which is trying to take inbound port  54321 and routing that to 'thing:80' inside.
object network thing
 host 192.168.1.27
 nat (inside,outside) static interface service tcp 54321 www
access-list outside_access_in extended permit tcp any host 192.168.1.27 eq 54321
but connecting from an outside connection to http://<static_ip>:54321 just times out
If I do
packet-tracer input outside tcp 8.8.8.8 60002 <static_ip> 80
it shows all ACL & NAT is fine
If I'm on the inside, I can access the service, so I know it's working
If all the above is OK - how can I see what's stopping it connecting?
You have the ports in your NAT statement swapped around.
Here is the format it should be in:
nat (<REAL-INTF>, <MAPPED-INTF>) static <MAPPED-IP> [service <tcp|udp> <REAL-PORT> <MAPPED-PORT>]
Please remember to select a correct answer and rate helpful posts
OMG so I do !! thank you for that spot :)
It all works correctly .. thanks you
