You can configure an exception for sites based on their IP address by using an ACL in a class-map. For example:
access-list http-acl deny tcp any host 65.55.40.183 eq www
access-list http-acl permit tcp any any eq www
class-map http-class
match access-list http-acl
policy-map global_policy
class http-class
inspect http
service-policy global_policy global
You would want to remove your default inspection as well. Any IP address that is denied by the http-acl will not be affected by the inspection engine.
Hope that helps.
-Mike
