ASA 5520: Not able to ping outside n/w from inside interface
ameyahanamsagar
I am new to ASA. I have set up a lab in GNS3.
I cannot ping the outside interface from inside or vice versa. I have tried adding ACL's, inspect icmp and everything that I found while searching for the solution.
My Current running config is:
ciscoasa(config)# show running-config
: Saved
ASA Version 8.4(2)
hostname ciscoasa
names
interface GigabitEthernet0
 nameif inside
 security-level 100
 ip address 172.16.0.1 255.255.255.0
interface GigabitEthernet1
 nameif outside
 security-level 0
 ip address 10.0.0.1 255.0.0.0
interface GigabitEthernet2
 shutdown
 no nameif
 no security-level
 no ip address
interface GigabitEthernet3
 shutdown
 no nameif
 no security-level
 no ip address
interface GigabitEthernet4
 shutdown
 no nameif
 no security-level
 no ip address
interface GigabitEthernet5
 shutdown
 no nameif
 no security-level
 no ip address
interface Port-channel1
 no nameif
 no security-level
 no ip address
ftp mode passive
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
object network nonat
access-list outside_access_out extended permit tcp any eq echo any eq echo
access-list outside_access_out extended permit ip any any
access-list outside_access_out extended permit ip 10.0.0.0 255.0.0.0 172.16.0.0 255.255.255.0
access-list inside_access_out extended permit tcp any eq echo any eq echo
access-list inside_access_out extended permit ip any any
access-list inside_access_out extended permit ip 172.16.0.0 255.255.255.0 10.0.0.0 255.0.0.0
access-list inside_access_in extended permit ip any any
access-list inside_access_in extended permit tcp any any eq echo
access-list inside_access_in extended permit ip 10.0.0.0 255.0.0.0 172.16.0.0 255.255.255.0
access-list outside_access_in extended permit ip any any
access-list outside_access_in extended permit tcp any any eq echo
access-list outside_access_in extended permit ip 172.16.0.0 255.255.255.0 10.0.0.0 255.0.0.0
access-list nonat extended permit ip 172.16.0.0 255.255.255.0 10.0.0.0 255.0.0.0
access-list nonat extended permit ip 10.0.0.0 255.0.0.0 172.16.0.0 255.255.255.0
pager lines 24
mtu inside 1500
mtu outside 1500
icmp unreachable rate-limit 1 burst-size 1
icmp permit any echo inside
icmp permit any echo outside
no asdm history enable
arp timeout 14400
nat (inside,outside) source static any any
nat (inside,outside) after-auto source dynamic any interface
access-group inside_access_in in interface inside
access-group inside_access_out out interface inside
access-group outside_access_in in interface outside
access-group outside_access_out out interface outside
router ospf 1
 network 10.0.0.0 255.0.0.0 area 0
 network 172.16.0.0 255.255.255.0 area 0
 log-adj-changes
route inside 192.168.1.0 255.255.255.0 172.16.0.2 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
user-identity default-domain LOCAL
aaa authentication http console LOCAL
http server enable
http 192.168.1.2 255.255.255.255 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart warmstart
telnet 192.168.1.1 255.255.255.255 outside
telnet timeout 5
ssh timeout 5
console timeout 0
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
username ameya password xxxxxxxxxxxxxxx encrypted
class-map inspection_default
 match default-inspection-traffic
policy-map global_policy
 class inspection_default
  inspect icmp
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
call-home
 profile CiscoTAC-1
  no active
  destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
  destination address email callhome@cisco.com
  destination transport-method http
  subscribe-to-alert-group diagnostic
  subscribe-to-alert-group environment
  subscribe-to-alert-group inventory periodic monthly
  subscribe-to-alert-group configuration periodic monthly
  subscribe-to-alert-group telemetry periodic daily
crashinfo save disable
Cryptochecksum:69a533dbabc0f5a84aaeee0c2054746a
: end
ciscoasa(config)#
Pings even dont work when I ping from outside interface to inside interface and vice versa.
ciscoasa# ping inside 10.0.0.1
Sending 5, 100-byte ICMP Echos to 10.0.0.1, timeout is 2 seconds:
Success rate is 0 percent (0/5)
ciscoasa# ping outside 172.16.0.1
Sending 5, 100-byte ICMP Echos to 172.16.0.1, timeout is 2 seconds:
ciscoasa#
rvarelac
Level 7
Level 7
Hi ameyahanamsagar
Ping from your inside interface to the outside interface  is not allowed on the ASA.
Try to create a virtual machine  and do the test or create a LAN environment, I'm pretty sure ping should work fine as long as the ASA keeps reachable .
I would add to the configuration:
ICMP permit any echo-reply in
ICMP permit any echo-reply out
Hope this help !
- Randy -
turbo_engine26
Level 4
Level 4
You are using too much ACLs in your configuration. Keep in mind that, by default, traffic from higher security interface (inside) is allowed to lower security interface (outside) without the need for any ACL. The only ACL you need is for traffic comes from outside to inside in the inbound interface direction. The "out" keyword is rarely used and should be avoided as it is only used for specific scenarios. Also, remove the current NAT configs and just create a simple dynamic PAT using Auto-NAT for the inside subnet. Twice NAT is a bit complex and used for specific situations.
I suggest to use the following configs:
access-list Outside_IN extended permit icmp any any echo (Not recommended in production)
access-list Outside_IN extended permit icmp any any echo-reply
access-group Outside-IN in interface outside
object network Inside_Subnet
subnet 172.16.0.0 255.255.255.0
nat (inside,outside) dynamic interface
I also suggest to ping live machines rather than ASA's own interfaces.
AM
