ASA 5525 problem with NAT and ACL
Frank27
I have a problem with this ASA. Cannot reach from the outside the inside network. Logs like that
A-3-710003: TCP access denied by ACL from 203.1.1.4/51022 to outside:10.0.0.3/443
%ASA-7-710005: TCP request discarded from 203.1.1.4/51022 to outside:10.0.0.3/443
%ASA-3-710003: TCP access denied by ACL from 203.1.1.4/51022 to outside:10.0.0.3/443
This is the relevant part of the running conf:
interface GigabitEthernet0/0
nameif outside
security-level 0
ip address 10.0.0.3 255.255.255.0
interface GigabitEthernet0/1
nameif VLAN
security-level 100
no ip address
interface GigabitEthernet0/1.1
vlan 20
nameif VLAN20
security-level 100
ip address 192.168.20.1 255.255.255.0
same-security-traffic permit inter-interface
object network VLAN20
host 192.168.20.2
object network outside_map
host 10.0.0.4
access-list INSIDE_IN extended permit ip any any
access-list tovlan extended permit icmp any host 192.168.20.2
access-list tovlan extended permit tcp any host 192.168.20.2 eq www
access-list tovlan extended permit tcp any host 192.168.20.2 eq https
nat (VLAN20,outside) source static VLAN20 outside_map no-proxy-arp
access-group INSIDE_IN in interface outside
access-group INSIDE_IN out interface outside
access-group tovlan  in interface VLAN20
access-group tovlan  out interface VLAN20
route outside 0.0.0.0 0.0.0.0 10.0.0.1 1
Any suggestions?
Thank You!
Looks like you are trying to access the server via your outside interface IP but you have defined 10.0.0.4 in your NAT statement.  Try accessing via 10.0.0.4.
Please remember to select a correct answer and rate helpful posts
