ASA 8.2 to 8.4 conversion help needed!
Jon Diers
I am having issues with a site to site tunnel between an ASA and a CheckPoint firewall.  All of the devices on 8.2 work fine but the new ones are not working.  Part of the config is not being copied over so I was hoping to get some help in the conversion of it.  Here is the code on the firewalls that work.  I know it is sloppy, sorry.
object-group network TUNNELINSIDE
network-object host 192.168.149.11
network-object host 192.168.149.20
network-object host 192.168.149.43
network-object host 192.168.149.44
object-group network TUNNELOUTSIDE
network-object fake ip 1
network-object fake ip 2
access-list outside_cryptomap extended permit ip object-group TUNNELINSIDE object-group TUNNELOUTSIDE
access-list outside_access_in extended permit ip object-group TUNNELOUTSIDE any
access-list inside_nat0_outbound extended permit ip object-group TUNNELINSIDE object-group TUNNELOUTSIDE
access-list inside_nat0_outbound_1 extended permit ip object-group TUNNELINSIDE object-group TUNNELOUTSIDE
access-group outside_access_in in interface outside
Global (outside) 2 outsidetunnel netmask 255.0.0.0
Nat (inside) 1 192.168.149.11 255.255.255.255
Nat (inside) 1 192.168.149.20 255.255.255.255
Nat (inside) 1 192.168.149.43 255.255.255.255
Nat (inside) 1 192.168.149.44 255.255.255.255
nat (inside) 0 access-list inside_nat0_outbound_1
The objects in TUNNELINSIDE are supposed to be able to connect back to our HQ without VPN connection and everyone else would use a VPN if they needed to connect.
Thanks in advance.
johnlloyd_13
Level 9
Level 9
hi,
you can use Cisco's free FW migration tool.
see helpful link for sample:
http://ccnpsecuritywannabe.blogspot.com/2016/01/cisco-asa-firewall-migration-tool.html
Don't you have to be a Cisco Partner to use that?  I am not..
You will need a CCO account but you do not need to be a Partner.
Craig
