ASA ACL problem
I don't know what's wrong with this:
Doing
access-list outside_access_in extended permit tcp any interface outside eq www
is working but this:
access-list outside_access_in extended permit tcp 172.12.33.0 255.255.255.0 interface outside eq www
is not working.
I've double checked the ip and I can even see it as the source ip in the log.
Why is the ASA do not recognise this ACL when the source ip is written?
Thanks!
7 Replies 7
Julio Carvajal
Hello Jean,
Is 172.12.33.0 subnet reachable for the ASA via the outside interface?
Julio
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
Yes it's my public IP.
I can see in the log that the ASA really identified it as the source IP trying to connect to it
Hello Jean,
Ok, so can you share your configuration so I can let you know why this is now working.
Julio
Julio Carvajal
It's only working with ANY source in the ACL.
if I put in my IP, it's not working.
And I'm truly sure the IP is good.
Hello Jean,
Can you post the running-configuration ( With some changes due to your own newtork security) We need to see what you want to acomplish, check the nat statements, access-group,complete ACLs,etc.
Ok so the network 172.12.33.0 /16 on the outside security zone is trying to access on port 80 the outside interface and its not working unless you configure the ACL with the tcp any interface outside.
Can you also share the following packet-tracer output:
packet-tracer input outside tcp 172.12.33.15 1025 x.x.x.x (outside ip address) 80
Julio
Julio Carvajal
I'll give you the part you'd need.
access-list outside_access_in extended permit tcp host 102.51.88.50 host 201.223.12.226 eq www  <-- This won't work
access-list outside_access_in extended permit tcp host 102.251.177.74 host 201.223.12.226 eq www  <- This won'T work
access-list outside_access_in extended permit tcp host 51.231.212.98 host 201.223.12.226 eq www  <- THis won't work
access-list outside_access_in extended permit tcp host 211.222.31.194 host 201.223.12.226 eq www <-- This won't work
access-list outside_access_in extended permit tcp 23.111.101.0 255.255.255.0 host 201.223.12.226 eq www  <-- This won't work
access-list outside_access_in extended permit tcp any host 201.223.12.226 eq www  <-- This work correctly
static (inside,outside) tcp interface www PBX www netmask 255.255.255.255
If I only put the ACL that does'nt work, it jumps directly to the "access-list outside_access_in extended deny"
Okay, lets do the following
Lets leave just the ACL withouth the tcp any any.
Lets create a capture ( For that you will need to generate some traffic from 23.111.101.x host)
access-list  capout permit tcp host 23.111.101.x host 201.223.12.226 eq 80
access-list capout permit tcp host 201.223.12.223 eq 80 host 23.111.101.x
access-list capin permit tcp host 23.111.101.x host PBX eq 80
access-list capin permit tcp host PBX eq 80 host 23.111.101.x
capture capin access-list capin interface inside
capture capout access-list capout interface outside
capture asp type asp-drop all.
Now generate the traffic
Then provide the following data
sh asp | include 23.11.101.x
Go to a browser : https://inside_interface_ip_address/capture/capin/pcap
https://inside_interface_ip_address/capture/capout/pcap
And upload to this discussion the files
Do rate helpful posts
Julio
Julio Carvajal
