ASA: AnyConnect using certificates does not work and shows error msg
swscco001
Level 3
Level 3
Hello everybody,
our customer has an branch ASA5516 (OS: 9.16(3)19) and when he try to access the ASA
using AnConnect (4.10) he get the error message window:
"Certificate Validation Error"
In the logging appears (complete logging attached):
No certificates received during the handshake with client outside:<client_IP>/21394 to <ASA_IP>/443 for TLSv1.2 session
He gets no window to enter username & password.
On the main site ASA he can login with certificates without issues.
There are no expired certificates on the branch ASA5516 and
NTP ssems to be ok:
Result of the command: "show ntp status"
Clock is synchronized, stratum 2, reference is 192.53.103.108
nominal freq is 99.9984 Hz, actual freq is 99.9376 Hz, precision is 2**6
reference time is e79dccdb.fbd38de7 (10:41:31.983 UTC Mon Feb 20 2023)
clock offset is -0.9559 msec, root delay is 69.02 msec
root dispersion is 16.72 msec, peer dispersion is 15.75 msec
It looks like the certificates were not used for AnyConnect at him.
I see another user is logged in by the same AnyConnect connection profile
to the brach ASA.
Attached you find the current configuration.
What is the best troubleshooting procedure here?
Thanks a lot for every hint!
Bye
R.
0 Replies 0
