ASA Connection uptime greater then timeout - Oracle CM to DB
gc227s001
We have recently migrated a set of Oracle eBiz DMZs from a FWSM to Cisco ASA.
There are intermittent disconnects of service between the Oracle Concurrent Connection Manager and the Oracle DB servers through the ASA.
General ASA health checks, CPU, Mem, interfaces etc all check out as okay.
The connection table does show healthy connections with UIO or UIOB flags.  However, when showing connections with detail I note that some connections in the table have an uptime that is larger then the TCP timeout value:
TCP Database-Server-LAN: 10.111.110.110/1522 Internal-App-Server-LAN: 10.111.110.45/43716,
    flags UIOB , idle 6m58s, uptime 6h57m, timeout 1h0m, bytes 1615889
I am looking for an expert eye to advise if this is normal or what I should be looking at or advising our Oracle guys to check.
0 Replies 0
