asa_csc_bypass_problem
iabhianand
hello sir,
with regarding to the firewall ASA5520, i'm using it in my network, all the confiuration are properly configured and working but with the use of proxy address in internet explorer(e.:206.53.155.129/3128) all the blocked contents as easily accessible simply it bypass all the network through firewall.so will u guide me to block the proxy servers.if u want the confiiguration than let me know,but as soon as possible provide me the solution for it.
varrao
Level 10
Level 10
Hi Abhi,
Can you share the policies that you have applied to direct the traffic to the CSC module? You might need to include the proxy server ip in the access-list that you have applied to redircet the traffic to CSC.
Varun
Varun Rao
