ASA CX 5512 problem with https, with inside webmail
Hi, we have a problem, with ASA CX 5512, anyconnect users can use webmail normaly, but, outside users, who came from outside interface (without anyconnect) cannot get webmail page, only got error 403 with some message about ssl problem, when we turn off CX module, everything works nice. :).
Any help ?
CCNA R&S, CCNA Security
Vibhor Amrodia
Did you try to disable the decryption policy and check if that helps ?
Thanks and Regards,
Vibhor Amrodia
No I did not disable anything, I did not configure ASA at first. Now I do not know how to turn on CX module, I found command to shut down, but I did not found command to turn on.
So , if i understand , you do not have the CX configured and evaluating the traffic ?
You can use this command to enable the CX from the Shutdown state:-
http://www.cisco.com/c/en/us/td/docs/security/asa/asa-command-reference/S/cmdref3/s17.html#pgfId-1609049
Thanks and Regards,
Vibhor Amrodia
